Old 12-26-2013, 09:00 PM   #1
jamesm
Screencast: experimenting with full-time closed loop fueling
[ame="http://youtu.be/bjek3zrC1o8"]http://youtu.be/bjek3zrC1o8[/ame]
Experimenting with full-time closed loop fueling using Ecutek RaceRom custom maps and an Innovate LC-1. Very experimental, but it works!
Old 12-27-2013, 09:44 AM   #2
s2d4
s2d4's Avatar
@jamesm
Looks like your setup is working well.
Any particular reason that you are using MAF flow instead of say throttle position or engine load?
Now that you have the wideband setup where the cannister input was, and I didn't see any spare inputs that be could used, how are you going to setup flexfuel?
Old 12-27-2013, 10:19 AM   #3
jamesm
Originally Posted by s2d4 View Post
@jamesm
i plan to use a hybrid sd/maf setup when it's all done. now that i have the closed-loop bit in place i can start tuning the ve map for the sd more safely. until the sd is tuned, it's just running maf full-time.
i'll probably stick to using two maps versus flex fuel, just because i'd rather have my wideband input, and i don't change fuels often.
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Screencast: Innovate LC1 logging with RaceRom jamesm Software Tuning 7 12-27-2013 06:59 PM
So I've been experimenting with a different setup the past few days... Vracer111 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-23-2013 09:11 PM
Screencast: generating fueling error charts with yike's spreadsheet jamesm Software Tuning 4 12-19-2013 09:44 PM
Franschhoek pass closed for some time Vladror AFRICA 1 11-18-2013 07:28 AM
