Old 03-09-2014, 06:52 PM   #1
STS-V
TRD Front bumper without stupid license plate?
Hi all,
On all the TRD front bumper kits I find, they all have the stupid license plate frame.
Any way to get one like this?
I mean that looks like a bad photoshop. Is the easiest way just to order and have someone cut?
STS-V is offline   Reply With Quote
Old 03-09-2014, 07:43 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
There used to be a vendor that was working on this, but it never seemed to finish. Custom might be your only choice at this point.
sirsol66 is offline   Reply With Quote
Old 04-21-2014, 10:26 AM   #3
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I'd really love a frameless version.
Do you think having the license plate on would block a lot of air for cooling?
blackfireball5 is offline   Reply With Quote
Old 04-21-2014, 01:49 PM   #4
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Majority of a normal plate is in front of the part of the grill with no holes. Or you could do what I did...I got a piece of aluminum made only large enough to fit the plate holder. It's only about 4" deep and does not cover any part of the grill that actually has holes. Painted it the same black as the TRD piece. Only thing that shows is the 2 small screw heads...and you could probably attach it with double-sided tape if you wanted an even cleaner look. Here is a link to my inspiration for the plate on the bumper...
http://www.ft86club.com/forums/showp...74&postcount=1
Once you black out the tag, it pretty much disappears. Does it look as good as actually eliminating the tag holder?.... No.
But is it a lot less trouble to just cover it up?....Yes. And the tag holder area of the TRD front is also an attachment point to help hold and stabilize the center of the piece to the bumper. My $.02 YMMV.
Here's mine...
cfordart is offline   Reply With Quote
The Following User Says Thank You to cfordart For This Useful Post:
blackfireball5 (04-21-2014)
Old 04-21-2014, 01:53 PM   #5
logoris
Drives: 04 is300 sport design ii
it looks like its made of 2 pieces so it doesn't look too hard to shave it, cut the top and bottom, sand the face flush, and poly filler where needed. Then you are good to go.
it is well known that aftermarket its usually need work to get to fit properly so its just a little bit more work then usual but it can be done.
logoris is offline   Reply With Quote
Old 04-22-2014, 05:01 PM   #6
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
The Release Series 1.0 TRD Lip Kit does not have the front license plate. The design is a bit different though.
Tuan is offline   Reply With Quote
Old 04-22-2014, 05:28 PM   #7
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
When does this release come out?
914_WHITE_FRS is offline   Reply With Quote
Old 04-22-2014, 05:35 PM   #8
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
http://www.worldcarfans.com/11404167...es/lowphotos#1
check out some pics. just release back in Jan 2014. new kit
Old 04-22-2014, 06:43 PM   #9
914_WHITE_FRS
where can i buy the kit
Old 04-22-2014, 06:52 PM   #10
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
That "lip" does not surround the main grill like the other one:
My plan: by that front and just delete the license plate out.
European Trim Black is your friend
hamzam is offline   Reply With Quote
Old 04-22-2014, 06:54 PM   #11
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
at least have to wait a month or so, i got contacted from oversea manufacture is going to produce the replica of this kit, but i didn't get an exact time frame from them when is it going release.
Old 04-22-2014, 07:00 PM   #12
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
The plate doesnt extend into the OPEN part of the grill look at pictures...I mean its the part that makes it ugly...but in Japan front plates are a requirement. So they integrated it to make it work with a front plate...
Fett4Real is offline   Reply With Quote
Old 04-22-2014, 07:35 PM   #13
blackfireball5
Now that I know it doesn't actually block airflow. *Maybe* I'll be ok with it. Lol. Since I have a vanity plate it might note be too bad. :-)
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 04-23-2014, 04:24 AM   #14
Tuan
Tuan's Avatar
Here is another OEM Body Kit released by Toyota Australia for the 86 GT-S without the front license plate.
Not a TRD, but I think still flows well with the car.
Help covering front bumper license plate holes JLMIAMI Cosmetic Modification (Interior/Exterior/Lighting) 56 01-27-2018 05:39 PM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
Front License plate/bumper protector Aloxi Cosmetic Modification (Interior/Exterior/Lighting) 3 11-20-2012 09:29 PM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
Stupid dealership license plate frame... Laika BRZ First-Gen (2012+) — General Topics 7 07-24-2012 06:37 PM
