Old 03-07-2014, 09:33 PM   #1
cooldandani
Drives:
Springs or coilovers?
Hey guys!! Sorry for the moon question but what is the difference between Springs and coilovers, thanks for the input!!
Sent from my LG-D950 using Tapatalk
cooldandani is offline   Reply With Quote
Old 03-07-2014, 09:42 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
This will definitely help you in the right direction:
http://bit.ly/1oyUy0q
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
eSOLOR (03-07-2014)
Old 03-07-2014, 10:07 PM   #3
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
PROS
Springs - Cheaper, legal (In states where coilovers aren't)
Coilovers - Ability to adjust height and damper settings. Also camber depending on the type.
DIFFERENCE
A Spring just replaces the stock spring around your stock shock. The length or spring rate will determine the stiffness of your suspension and height of your car. These cannot be adjusted unless you couple the spring with an aftermarket skock.
A Coilover is like an aftermarker spring and shock in one unit.
Wise is offline   Reply With Quote
Old 03-07-2014, 10:11 PM   #4
cooldandani
Drives:
Originally Posted by Wise View Post
PROS
DIFFERENCE
Thanks so much!! Very useful info, you happen to be running Springs or coilovers?
Old 03-07-2014, 10:13 PM   #5
Wise
Circle Work Clerk
I have a set of Eibach Pro Kit springs for now. They just drop the car 1" or 25mm.
Old 03-07-2014, 10:19 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Coilovers.
Your stock strut is not engineered to be used with lowering springs. You're going to blow your stock struts sooner than you should and then you'll have repurchase new struts.
Might as well do it right the first time and have coilovers because they're engineered to be lowered.
Old 03-07-2014, 10:21 PM   #7
cooldandani
Drives:
Hmm okay well Idk what to go for, any decent set of coilovers for under 1000$?
Old 03-07-2014, 10:25 PM   #8
N1rve
N1rve's Avatar
Plenty.
http://ft86speedfactory.com/suspensi...ndex-1-3a.html
The Following User Says Thank You to N1rve For This Useful Post:
LXXXV1 (03-18-2014)
Old 03-07-2014, 10:29 PM   #9
cooldandani
Drives:
Oh nice any recommendations specifically?
Old 03-07-2014, 10:37 PM   #10
N1rve
N1rve's Avatar
When I had my Altima, they weren't satisfied with the Megan Racing EZ because it didn't lower the car enough for their liking. I don't know if the issue is still here.
I'd go with the EXTREME LOW by BC Racing... just because MOAR LOWWW.
Old 03-07-2014, 10:39 PM   #11
cooldandani
Drives:
Lmao yeah that'll be sexy, well I'll do a little more research and see what I end up getting
Old 03-07-2014, 10:45 PM   #12
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
As far as I'm aware, the only blown struts that have been reported were a result of bad spring installation. And even though though the dampers may be under a little more stress, our cars were actually designed to have optimum geometry at an 20mm drop.
But you left out the only important bit. Why are asking this? show or go?
Old 03-07-2014, 10:56 PM   #13
cooldandani
Drives:
Of course I'm planning on lowering my car they look sexy as fuck lowered lol just don't have much experience in that field so I'm taking my time and researching to find what I want,
Old 03-07-2014, 10:58 PM   #14
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Anyone have ridiculous miles on springs with stock struts?
springs vs coilovers?? which is best? FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 06-11-2013 02:09 PM
Springs or coilovers. Itssrayyxd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 04-26-2013 08:32 AM
Coilovers vs. Springs??? FrSnake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-18-2013 04:10 PM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
