View Poll Results: Which suspension upgrade would you want
Coilovers 52 65.82%
Springs 27 34.18%
Voters: 79. You may not vote on this poll
Old 03-27-2012, 04:06 PM   #1
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
coilovers or springs?
Which do you guys think you will get?
Also cons and pros of each?
koyv90 is offline   Reply With Quote
Old 03-27-2012, 04:15 PM   #2
Racecomp Engineering
This gets asked a lot and IMO the answer is it depends!
Lots of crappy springs out there.
Lots of crappy coilovers out there.
One is not always better than the other and what works for one person may not be ideal for you. Can't write any more at the moment...back to the shop.
- Andrew
Old 03-27-2012, 04:30 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Love RCE's commitment to the FT community. Their commitment to the STI community is one of the big reasons why I chose them when I did the STI.
Back OT: I'm going springs. I'm not planning to compete for points with my BRZ, so the higher cost of coil-overs isn't fully justified, nor is the added adjustability needed. Especially as it looks like RCE will have a set of "Black" springs for us who DD our cars.
I know I can probably find a set of coilovers for the price of springs+mounts, but I don't put junk on my cars; and to be honest, a set of $1K coilovers is only going to be junk.
Old 03-27-2012, 04:49 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
coilovers are springs.. that coil over a damper
the question you should be asking yourself is "am i going to corner balance my car", and only you can answer that question.
Old 03-27-2012, 05:18 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
There's no need to be flippant. He's obviously implying "damper/spring solution in a box" versus "spring replacement for otherwise stock suspension".
It's also inappropriate to answer this question, as we have no suspension stroke measurements.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-27-2012, 06:06 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
ya but somebody has to bag on him eventually
otherwise he'll read a bunch of things and be all like
"yo my coilovers are wesum why you still on springs bra"
Old 03-27-2012, 06:26 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Exactly, coil overs give you a lot more opportunity to screw things up. And they're really only useful for fixing an issue. From the corner weights we've seen, I doubt you could gain much over a set of simially damped dampers and springs.
I'll be looking for a mild drop with a linear rate and a set of good dampers. RCE, swift, or pink springs from Subarugenuineparts.com is where I'll start my search for springs. Koni will be getting my money for dampers.
Old 03-27-2012, 06:36 PM   #8
buckets
buckets's Avatar
Drives: infiniti g37x
Looking forward to swift springs
buckets is offline   Reply With Quote
Old 03-27-2012, 10:25 PM   #9
koyv90
Rocket Bunny FRS
Well i thought people liked full sets of coilovers because if you dump your car the ride quality is better, plus they help in corners more so because of the on the fly switching of rates/ride height.
Also I don't know about you guys but what crappy companies?
The only ones i Have heard about are Buddy Club(which i have on my rsx and work fine), Tein, Mugen, Tanabe, And function and form(This one being like a knock off of the others but still okay).
Sorry coming from clubrsx and honda forums coilovers don't seem to terrible. But if its just lowering springs could do the job just as good.
Old 03-27-2012, 10:29 PM   #10
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
are coil overs gonna help me pull 1g??
poormans_LFA is offline   Reply With Quote
Old 03-28-2012, 12:18 AM   #11
Sasquachulator
Pavement Grey
Its not really on the fly unless you have the electronic setup.
Otherwise its more like adjustability is based on how fast you can take out your wheels, rotate the coils with the dinky ass coil wrench and line it up properly with each other wheel.
I'd go coils only mainly for winters. If i end up having this as an only car i'd like to jack up the ride height for those snowy seasons (hey i live in Canada, half the time it snows) Otherwise the car is just another snowplow.
Old 03-28-2012, 04:30 AM   #12
Levi
Drives: Toyota
Springs from some good brand (Eibach, KW, Bilstein,...) if you just want to lower the car for good looks.
Full coilover kit of good brand and version (KW Clubsport, AST/Moton, Bilstein, Öhlins,...) if you know what you are doing and are tracking your car regularly.
So to answer you question for a street car springs, for a trackcar coilovers, but can't tell yet as I have first to drive an test it and adapt to situation and needs.
Levi is offline   Reply With Quote
Old 03-28-2012, 08:29 AM   #13
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you just want to pull 1G buy a set of RS3, RE11, StarSpecs or anything else in that regard. Won't need to ever touch the suspension.
anything stickier will only make you corner faster, again, no need for suspension upgrades.
Old 03-28-2012, 08:32 AM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
IF, and only IF the coilover is designed with a shorter body (for wishbone suspensions, ie, the rear of the car) or if the body is shorter and or adjustable at the mounting point to the hub (this is for MacPherson struts) then you may retain comfort while going lower.
however in some applications this can be achieved in a regular damper + spring combo with no adjustability (such as inserts, case in point, subarus)
the point is, it is not black and white.
BRZ lowered on RaceComp Engineering springs! OrbitalEllipses Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 03-19-2014 06:26 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
$105 Track Day@ Streets of Willow Springs- Nov 26-27 in SoCal Louie Southern California 1 11-25-2011 12:45 AM
$105 Track Day@ Streets of Willow Springs- Oct 29 in Socal Louie Southern California 1 10-28-2011 03:50 AM
$95 Track Day@Willow Springs March 11 Louie Southern California 0 01-23-2011 01:38 AM
