Old 03-04-2014, 01:27 PM   #1
FRSure
Drives: Toyota
H11 LED Foglight
Anyone know if these are any good and if they fit the foglights for Diode Dynamics?
http://www.ebay.com/itm/H8-H9-H11-CR...83e956&vxp=mtr
FRSure is offline   Reply With Quote
Old 03-04-2014, 08:39 PM   #2
FRSure
Drives: Toyota
Bumpity bump
Old 03-04-2014, 11:25 PM   #3
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Originally Posted by FRSure View Post
Bumpity bump
LED bulbs are pretty pointless if you actually want range or to be able to see with them. They'd just be a "bling" item.
Trashed675 is offline   Reply With Quote
Old 03-05-2014, 04:13 PM   #4
Diode Dynamics
Diode Dynamics's Avatar
Depends on which stage you go with, our Stage 3's will provide some usable light output, but HIDs are still the best route to take for the most usable output.
The Stage 1's and 2's are intended primarily for cosmetic appearance
Nick C.
John C.
Diode Dynamics
Old 03-05-2014, 07:32 PM   #5
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
HIDs? So you can blind every person in the oncoming lane? Not smart, or safe.
Deathalo is offline   Reply With Quote
Old 03-06-2014, 12:19 PM   #6
Diode Dynamics
The position of the arc with our HID bulbs closely matches the filament position of the halogen bulb it replaces. It will generate more light, but it also does an excellent job utilizing the factory housings.
Projectors are the best solution, but with a 35 watt kit and a low car like the FR-S, you won't be blinding anyone.
http://www.diodedynamics.com/store/research.html
Nick C.
John C.
Diode Dynamics
Old 03-06-2014, 06:48 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
you should talk to markus on hidplanet about that one. he'll kindly correct that statement after he beats you over the head with it.
hid bulbs have 2 hotspots, one at the each end of the arc, which makes the beam output incompatible with halogen optics that are designed around a single hotspot of a burning filament.
Old 03-06-2014, 08:23 PM   #8
FR-Slide
Drives: 13 Whiteout 6MT
So 35W is safe in plastic fogs? I know a lot of the Subaru/Yota fogs are 19v OEM, but most aftermarket bulbs (halogen) are 35W, and 35 is the min for HID as well.
Just checking before I burn anything.
FR-Slide is offline   Reply With Quote
Old 03-06-2014, 09:56 PM   #9
soundman98
soundman98's Avatar
it really depends on the actual quality of the bulb.. just keep in mind that there are absolutely zero standards regarding uv output, or focal point when it comes to hid h-based bulbs, so it's all pretty much a crapshoot weather you'll get a bulb with near-oem specs, or one that requires spf 100 just to install...
this is my experience with h-based bulbs.
http://www.club3g.com/forum/show-shi...on-inside.html
if it burns the plastic in the housing, it's a good enough reason for me to not have any desire to use them...
Old 03-06-2014, 10:01 PM   #10
FR-Slide
Was actually considering going with a halogen 35w.
Old 03-07-2014, 11:37 AM   #11
KI_ZN6
KI_ZN6's Avatar
For FR-S foglights, we have a few LED and halogen bulb options available. HIDs are also available for foglights, but it is important to note that it does produce glare for oncoming traffic (being non-projector lens) and therefore the foglights may need to be aimed low to minimize the glare as much as possible.
KI_ZN6 is offline   Reply With Quote
FRS Foglight Switch? 636 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-10-2015 04:47 AM
Foglight Cost FRSure Cosmetic Modification (Interior/Exterior/Lighting) 10 12-04-2013 04:57 PM
FS: JDM rear foglight kit Simply_the_best NY / NJ / CT / PA 19 10-02-2013 05:12 PM
FS: oem foglight stalk GT86drifter Exterior Parts (Aero, Lighting, Etc.) 3 05-15-2013 09:38 AM
FS: FNA Rear Foglight Kit 3 jmelgar23 Exterior Parts (Aero, Lighting, Etc.) 1 04-18-2013 01:53 PM
