Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 09-19-2013, 02:22 PM   #1
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
FS: JDM rear foglight kit
I will be making rear jdm fog light harness' for the FR-S/BRZ. All using OEM parts. Only thing is the reverse lamp housing needs to be drilled for the rear fog light. @GT86drifter can vouch for the parts he has seen and purchased one of these. I can install all of this as well for a small fee. The kit price is $55 shipped. pm me if interested.
parts included in the kit:
-Rear lamp housing harness WITH bulb
-Wiring to the front of the vehicle for install. This has a clip that plugs into the rear harness.
Super clean install.
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 09-19-2013, 02:26 PM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Does it include a relay and pins for the main body ECU? Also, will it connect to an EDM stalk?
kmbkk is offline   Reply With Quote
Old 09-19-2013, 02:40 PM   #3
Simply_the_best
Tom's Racing ADDICT
No relay or pins. Depends on how it is wired up. Mine is fused to a separate switch up front. You could still wire it to the EDM stalk but you would need to extend the wire and get a pin that would fit the stock wiring to the stalk. The pins I have are too big.
Old 09-19-2013, 03:08 PM   #4
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
I'll get the write up for this to a EDM/JDM stalk once i get it together.
GT86drifter is offline   Reply With Quote
Old 09-19-2013, 03:18 PM   #5
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
So, does it light up when braking or does it just light up when you turn on the headlights?
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 09-19-2013, 03:26 PM   #6
Simply_the_best
Tom's Racing ADDICT
Thanks.
That solely depends on how you wire it. I have it wired to the tail lamps. It only lights up once the tail lamps light up. Does not light up with brakes, it is already very bright. Mine is also to a switch so I can turn it off need be.
Old 09-19-2013, 04:07 PM   #7
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
You can wire it so it's only comes on with the front fogs too
http://www.ft86club.com/forums/showthread.php?t=37507
Scenic Driver is offline   Reply With Quote
Old 09-19-2013, 04:10 PM   #8
Simply_the_best
Tom's Racing ADDICT
Yes.
Old 09-19-2013, 04:28 PM   #9
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Cool, thanks! I have the wiring figured out for use with a JDM/EDM stalk, just unable to do it due to deployment. The only thing I haven't nailed down is the ECU/stalk pins.
Old 09-19-2013, 06:43 PM   #10
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
I'm interested. Definitely want to check it out at the meet tomorrow.
immaculate is offline   Reply With Quote
Old 09-22-2013, 12:09 AM   #11
jinberry
Slow 'n' Steady
Drives: FR-S Whiteout
bring a set next wednesday. I'm doin it
jinberry is offline   Reply With Quote
Old 09-22-2013, 03:17 PM   #12
yuroldhat
Drives: Scion FR-S
^+1
Bring one for me too.
yuroldhat is offline   Reply With Quote
Old 09-23-2013, 01:40 PM   #13
Simply_the_best
Tom's Racing ADDICT
Originally Posted by yuroldhat View Post
^+1
I will bring them only thing is that I'm not going to be there this Wed. 9/25 going to MD. The following Wed. 10/2 I will bring with me 2 wiring kits for you guys. Anyone else?
Old 09-26-2013, 11:12 PM   #14
delusional
B R Z
delusional's Avatar
Drives: BRZ 6MT Limited
i'll take one. how much for you to install it too?
delusional is offline   Reply With Quote
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Rear Foglight Enable Tye300 DIY (Do-It-Yourself) Guides 73 05-09-2017 01:37 PM
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Rear Foglight Delete Kit? smbstyle Cosmetic Modification (Interior/Exterior/Lighting) 7 04-25-2013 06:34 PM
FS: FNA Rear Foglight Kit 3 jmelgar23 Exterior Parts (Aero, Lighting, Etc.) 1 04-18-2013 01:53 PM
