Old 03-02-2014, 12:52 PM   #1
thebus
Drives: Whiteout
FRS oil Pressure Scangauge
I have my Scangauge w/ Xcommand and i can get the oil temp..was wondering if there has been anyone to get oil pressure off of the car without running a typical gauge more importantly on the scangauge..
thebus is offline   Reply With Quote
Old 03-02-2014, 01:09 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
The car doesn't have a pressure sensor, only an on-off type sensor. If you want to measure oil pressure you need to add an oil pressure sensor.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-02-2014, 01:11 PM   #3
thebus
Drives: Whiteout
Thanks!
Scangauge oil temp xgauge code [Working] pkny Engine, Exhaust, Transmission 125 12-26-2022 11:11 AM
ScanGauge II Xgauge AFR {WORKING} AZFA20 Engine, Exhaust, Transmission 6 01-20-2015 06:37 PM
Scangauge II w/ XGauge OBDII Gauge and Scanner smbstyle Interior Parts (Incl. Lighting) 1 10-10-2014 02:37 PM
Scangauge II w/ XGauge - OBDII gauge and scanner smbstyle Audio/Visual, Electronics, Infotainment, NAV 2 01-27-2014 08:10 AM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
