Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 01-27-2014, 07:28 AM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Scangauge II w/ XGauge - OBDII gauge and scanner
Selling the Scangauge II OBDII gauge and scanner I have (with X-Gauge), where you can program all kinds of specific gauge readings that the stock ECU pics up, including throttle %, oil temp, water temp, etc. Also allows you to read and clear trouble codes on the fly.
$105 shipped.
Here is a thread with a bunch of different reading displays you can program into the Scangauge II:
http://www.ft86club.com/forums/showthread.php?t=28374
I spent a lot of time testing different mounting locations, and ended up with a great spot to mount it that is right under the OEM gauge cluster, and fabbed up my own custom mount using ABS plastic and double sided high strength 3M automotive tape.
It has worked great, doesn't interfere with the OEM gauges, but blends in well, and stays in place.
Only thing is there is a very light scratch on the screen and lower part of the casing.
It is ready to be installed; even put fresh 3M high strength automotive tape on the mount so it is ready to go in.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-27-2014, 08:08 AM   #2
Drobinson1692
Drives: 2007 Honda S2000
may i ask reason for selling?
also, not trying to low ball, but would you do 91? all i have in paypal
Drobinson1692 is offline   Reply With Quote
Old 01-27-2014, 08:10 AM   #3
smbstyle
smbstyle's Avatar
Selling b/c I'm planning on going with an OpenFlash tablet which will provide me with the same information.
Sorry, not flexible on price at this time.
2013 SWP BRZ
Scangauge oil temp xgauge code [Working] pkny Engine, Exhaust, Transmission 125 12-26-2022 11:11 AM
ScanGauge II Xgauge AFR {WORKING} AZFA20 Engine, Exhaust, Transmission 6 01-20-2015 06:37 PM
Scangauge II w/ XGauge OBDII Gauge and Scanner smbstyle Interior Parts (Incl. Lighting) 1 10-10-2014 02:37 PM
ATI Vent Pod 60mm & PLX DM-200 OBDII Scan Gauge Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-28-2013 01:21 PM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
