Old 01-26-2014, 04:08 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Scangauge II w/ XGauge OBDII Gauge and Scanner
Selling the Scangauge II OBDII gauge and scanner I have (with X-Gauge), where you can program all kinds of specific gauge readings that the stock ECU pics up, including throttle %, oil temp, water temp, etc. Also allows you to read and clear trouble codes on the fly.
$105 shipped.
Here is a thread with a bunch of different reading displays you can program into the Scangauge II:
http://www.ft86club.com/forums/showthread.php?t=28374
I spent a lot of time testing different mounting locations, and ended up with a great spot to mount it that is right under the OEM gauge cluster, and fabbed up my own custom mount using ABS plastic and double sided high strength 3M automotive tape.
It has worked great, doesn't interfere with the OEM gauges, but blends in well, and stays in place.
Only thing is there is a very light scratch on the screen and lower part of the casing.
It is ready to be installed; even put fresh 3M high strength automotive tape on the mount so it is ready to go in.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 10-10-2014, 02:37 PM   #2
Njnickd
Njnickd's Avatar
Drives: 2015 brz Blue series
Still for sale?
Njnickd is offline   Reply With Quote
Scangauge oil temp xgauge code [Working] pkny Engine, Exhaust, Transmission 125 12-26-2022 11:11 AM
ScanGauge II Xgauge AFR {WORKING} AZFA20 Engine, Exhaust, Transmission 6 01-20-2015 06:37 PM
ATI Vent Pod 60mm & PLX DM-200 OBDII Scan Gauge Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-28-2013 01:21 PM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
FS: VARAD VS350BL Scanner ***SOLD*** JPxM0Dz Canada Classifieds 0 05-18-2013 12:16 AM
