Old 02-26-2014, 06:12 PM   #1
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Ecutek logging
Is it possible to save the parameters for what parameters to log?
It would make it alot easier no having to change them each time i fire up the pc.
I am getting a e-tune and have to recheck/uncheck what parameters to log each time...
(I might also add that I am using all 10 thumbs when it comes to computers...)
Andreas83 is offline   Reply With Quote
Old 02-26-2014, 06:30 PM   #2
jamesm
no, there is not. this is an often-requested feature. i would also appreciate this very much lol.
Old 02-26-2014, 10:49 PM   #3
Circuit Motorsports
Circuit Motorsports's Avatar
Send a message via AIM to Circuit Motorsports
Andreas,
This feature is not implemented yet, but I know it is on their software enhancement list.
We would ALL love to have this ability!
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 07-09-2018, 10:57 PM   #4
q335r49
Drives: 2013 scion fr-s
One workaround is to use Autohotkey to send a series of keys (PgDown, Space, and Up and Down) to select the parameters you need. You can probably just modify the code I use below.
- Download autohotkey
- Paste the code below into an .ahk file.
- Modify the sequence of Up, Down, PgUp, PgDn, and space keypresses below. Note that the space key press to select a logging parameter appears as " " in all places except the end of the line of code, where it appears as {Space} since Autohotkey automatically trims spaces at the end of a line.
- Run the script.
- Select a set line in the Ecutek program (such as "All Parameters"), and press F4.
Code:
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
; #Warn  ; Enable warnings to assist with detecting common errors.
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir%  ; Ensures a consistent starting directory.
F4::
Send, {PgDn 2}{Up 13} {Down} {Down} {Down} {Down 39} {Down} {Down} {PgDn 4}{Up 12}{Space}
ExitApp
q335r49 is offline   Reply With Quote
Can you run ecutek data logging on a samsung windows tablet Frs32907 Software Tuning 10 02-09-2016 10:30 PM
Ecutek Deltadash data logging advanced functions Yruyur Software Tuning 8 08-20-2013 01:10 PM
ECUTEK Logging pdreams Engine, Exhaust, Transmission 5 02-05-2013 10:06 AM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 02:56 PM
