Old 02-08-2014, 09:16 AM   #1
z3ro
Generic Turbo Usage
So just to preface; I'm not an FI guy and know very little beyond the basic concept of turbos & supercharges and what they do.
With that being said, why is no one grabbing a stock WRX turbo, which can be had for under $300, or a Lancer turbo, which seemed more expensive, and running these? I figure with it all said and done you'd be looking at around ~$1,500 for some noticeable gains. Also, IMO, these smaller turbo's would put less wear and tear on your engine internals
z3ro is offline   Reply With Quote
Old 02-08-2014, 09:21 AM   #2
raven1231
They don't just bolt up
Old 02-08-2014, 09:23 AM   #3
z3ro
You couldn't have mating plate milled?
Old 02-08-2014, 09:23 AM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
There is more to it than that.. a lot more.
Sure you can use one of those turbos.. but when you are spending $3k+ on charge pipes, manifold, down pipe, sensors, tune, etc.. most would rather spend a couple hundred more to use a nice turbo with more headroom instead of an old OEM one.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-08-2014, 09:23 AM   #5
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
The turbo doesn't have to be the most expensive part of going FI, the price climbs sharply when you factor in the headers, intercooler, down pipe, BOV, piping, and all the other bits that make up a turbo kit. Not to mention the R&D costs.
- AdrianG
AdrianG is offline   Reply With Quote
Old 02-08-2014, 09:36 AM   #6
lexusb3
Drives: FRS
And tires lol
lexusb3 is offline   Reply With Quote
Old 02-08-2014, 09:46 AM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I think you're looking for this:
http://www.realhomemadeturbo.com/
If you know what you're doing and not afraid of a MIG and a chopsaw, this is where you start. I've boosted 6 cars on the cheap, all proved to be very reliable too. Just don't ask any dumb questions there or they will tear off your head and shit down your neckhole.
SloS14 is offline   Reply With Quote
The Following User Says Thank You to SloS14 For This Useful Post:
z3ro (02-08-2014)
Old 02-08-2014, 09:55 AM   #8
mrk1
Drives: Sterling BRZ Ltd
I was very close to building my kit around subi factory fit turbos. The problem is using the subi flanges just complicates things a bit more then the universal t3 flanges. If I ever wanted to upgrade the turbo to say a gt30 you have to pay a premium to get it in subi fitment.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-08-2014, 09:56 AM   #9
z3ro
See here is the thing; i don't think I'd want to. Just a little boost as the car only really ever see's daily driving. Just a little more power to make the country roads here a bit more fun
Old 02-08-2014, 10:01 AM   #10
mrk1
Ok then it could be a good fit for you. If I still had my 08 STI turbo I probably would have used that. I ended up using a t3 flanged garrett I had instead.
I believe Crawfords kit is based around subi fitment turbos.
The Build Thread
Old 02-08-2014, 10:04 AM   #11
mrk1
There is a decent selection of subi turbos from the vf48 to the td04.
The Build Thread
Old 02-08-2014, 07:21 PM   #12
z3ro
Originally Posted by vgi View Post
as others have said, besides turbo there is a lot more. 1.5k could only get you hot pipes
id beg to differ but maybe you're right. I'm a reasonably good fabricator with 7+ years of metal working and welding background. I think if i did a lot of the work myself i could keep it below that number
Old 02-08-2014, 09:56 PM   #13
mrk1
It all depends on what you put into the setup, doing a basic kit with a used subi turbo and keeping the internal wastegate, could probably be done at home for under that.
the manifold I made myself, this was going to have the subi inlet flange.
I'm pretty up tight about details so those 1/2 stainless flanges are probably more money then most people want to spend on a set of flanges.
The Build Thread
Old 02-08-2014, 09:57 PM   #14
z3ro
why such beefy flanges? isn't 1/4" generally acceptable? 3/8" would be good as well
Scratches from Window Usage? DieselxIndustry Issues | Warranty | Recalls / TSB 27 03-08-2015 08:03 PM
Best kit for occasional track usage yomny Forced Induction 14 02-06-2014 08:10 AM
Help: keyless access trunk usage ohtheantics BRZ First-Gen (2012+) — General Topics 13 09-07-2013 02:17 AM
Generic Fit Wing? Khorne Cosmetic Modification (Interior/Exterior/Lighting) 12 09-02-2013 02:48 PM
FR-S/BRZ Generic in design? FR_Soldier_77 Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2013 11:29 AM
