Old 05-01-2013, 11:26 AM   #1
DieselxIndustry
Drives: 2013 Firestorm FR-S
Scratches from Window Usage?
Has anyone noticed small vertical scratches forming near the center of the window? I am trying to get a picture of it, its just a hard shot to get. I've noticed them on both sides in the same spots.
DieselxIndustry is offline   Reply With Quote
Old 05-01-2013, 11:27 AM   #2
OrbitalEllipses
Drives: Attitude
Passenger side, dead middle of the window on the outside face. 2-3" vertical scratch that you can feel with your fingernail. I assume it came from the guide ribbon/track on the inside of the door. Haven't bothered with going to the dealer yet for time/they suck reasons.
Old 05-01-2013, 11:37 AM   #3
Asphalt~86
Drives: Asphalt AT
Also have them. Messed up my tint.
Asphalt~86 is offline   Reply With Quote
Old 05-01-2013, 11:44 AM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this is a common problem with frame-less subaru doors. The window guides get dirty and scratch the window.
my Impreza had pretty noticable scratches. This is the same as never cleaning your wipers, they will scratch your windshield over time.
there are two ways to help prevent this/reduce severity
1. clean your windows! keep a rag in the car and clean the dust off the door windows, esp during warmer weather when you know you'll be rolling them down
2. regularly clean the liner when the window is fully down. Do this often in the summertime. I use a rag with a mild solvent and jam it in there and wipe.
and in general, think before you roll down. If you need to roll down your window and you see that it’s REALLY dirty, try not to.
You can also do the “fake fur” mod that the impreza guys have been doing for years. You take apart the door to get to the WINDOW GUIDES and clean them or glue on a piece of fake fur, this helps it slide better. Check up on it once a year.
The Following 4 Users Say Thank You to 7thgear For This Useful Post:
Anthonytpt (05-01-2013), CamryDS (05-01-2013), HunterGreene (05-01-2013), TommyFive (05-01-2013)
Old 05-01-2013, 11:57 AM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
This is what happens with frameless windows. My celicas all had that "problem".
Rayme is offline   Reply With Quote
Old 05-01-2013, 12:13 PM   #6
DieselxIndustry
Wow, I'm surprised so many people have this. It's a pretty stupid issue to have not fixed over the years though. I'm also really good about keeping my car clean so its pretty surprising if that is a contributing cause to the scratches forming. Curious what Toyota/Subaru will say long term.
Old 05-01-2013, 12:15 PM   #7
jstn
Drives: '15 Vortech Supercharged
No scratches on mine but they squeak like crazy when they're wet. Super annoying.
jstn is offline   Reply With Quote
The Following User Says Thank You to jstn For This Useful Post:
Hardrock4445 (05-01-2013)
Old 05-01-2013, 12:18 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do you get right into the window crevase when it's all the way down?
i also sometimes tape a piece of scotch where the guides are and roll up and down a few times to help clean it up the best i can
after the impreza i will do everything i can to reduce the scratches.
as for fixing, it's a 26k car, you get what you pay for.
Old 05-01-2013, 12:23 PM   #9
DieselxIndustry
Not as well as I should but I will now, and thanks for the advice, I will definitely try it. It's not bad enough yet to need fixing but my old Eclipse never did that and it was frameless and an even cheaper car.
Old 05-01-2013, 09:26 PM   #10
Jayde
Jayde's Avatar
Just stating that my drivers side has scratches in two different areas of the window.
Jayde is offline   Reply With Quote
Old 05-05-2013, 12:56 AM   #11
sharky23
Drives: 2013 FR-S Ultramarine
I've noticed two lines parallel to each other on both glasses driver/ passenger I figured it was the guides. Will the dealer replace your windows if the get scratched from this?
sharky23 is offline   Reply With Quote
Old 05-05-2013, 03:15 AM   #12
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Frameless windows seem to have a lot of problems...scratches, sticking in freezing weather, seals getting messed up, etc.
Any actual pro's to going with frameless over traditional?
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 05-07-2013, 09:24 AM   #13
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
It looks cooler with the window down when you open the door
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
The Following User Says Thank You to WRXGuy1 For This Useful Post:
cmspooner (05-09-2013)
Old 05-07-2013, 10:07 AM   #14
Jayde
Jayde's Avatar
THIS! :happy0180:
Scratches on Outside of Driver's Window NewmarketBRZ Issues | Warranty | Recalls / TSB 56 09-26-2018 04:57 PM
minor scratches..... jazztennor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 02-06-2013 12:01 AM
scratches - best way to handle them Vladror AFRICA 6 02-03-2013 04:05 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
Stock tires usage in winter? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 07-13-2012 09:38 AM
