Drives: Subaru BRZ Limited WRB Manual
Clutch Engagement Improved!
All hail the WORKS KICK CLUTCH PEDAL STOP!
![]() ![]() ![]() I just bought this and installed it (it's a PIA if you have big fingers, but still less than 10 min). If you are the kind of manual driver who typically pushes the clutch all the way to the floor every time you shift - as opposed to only pushing it as far as necessary - then get this and install it. I am in love with the difference it makes. I know it seems silly in theory, and it's a lot of money for what it is, but I really like mindlessly pushing the clutch to the floor and getting quick, consistent engagement. |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Drives: Subaru BRZ (6027xx) Premium Manual
I'm with you on the "mindless" part!
Did you adjust your clutch pedal height in the process or it wouldn't work because of not enough pedal travel (low height + bumper)?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
I've adjusted the clutch many times, also tried removing that helper spring. Adjusting the pedal only raises or lowers how high the pedal comes up when not being pushed down, reducing travel from the front end basically. This clutch stopper changes how far down you can push the pedal in, reducing travel from the back end.
Drives: FR-S 10 #103 AT
In the Speed3 I had there was a convenient place to put in a bolt under the pedal and do the same thing for a few cents. It is a lot easier than training your foot to not go all the way to the floor. Especially when you are ripping through the gears.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
Exactly. That's basically what this is, but it has a nice plastic or rubber piece so you're not pushing metal against metal.
Not trying to be a ****
Drives: BRZ - 6MT - GBS
Pic? Link?
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
That's definitely attractive to me but I also adjusted the pedal because, by default, it stands too high to my taste (and I sport a healthy size 12!)
#10 | |
Audio & Bacon Junkie
Drives: 2013 WRB BRZ Ltd
Copy and pasting the link into a post seems to have worked on my machine
#11 |
Fanboy
Drives: 2013 ultramarine frs
looks like a $5 trip to home depot to me...
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#12 |
#13 |
Drives: WRB BRZ
#14 |
Drives: Asphalt Scion FR-S
The hole for that clutch stop is for a #8 size thread.
| whining/whirring noise during high load/rpm clutch engagement | 7thgear | Issues | Warranty | Recalls / TSB | 105 | 06-19-2017 11:04 AM |
| clutch Engagement Issue? | Bu-Tang | Issues | Warranty | Recalls / TSB | 68 | 02-19-2017 02:03 PM |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| DI seal improved material | radroach | Engine, Exhaust, Transmission | 21 | 01-16-2014 12:42 AM |
| Clutch Pedal Engagement Adjustment | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-25-2012 05:01 PM |
