Old 01-31-2014, 11:42 AM   #1
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Clutch Engagement Improved!
All hail the WORKS KICK CLUTCH PEDAL STOP!
I just bought this and installed it (it's a PIA if you have big fingers, but still less than 10 min). If you are the kind of manual driver who typically pushes the clutch all the way to the floor every time you shift - as opposed to only pushing it as far as necessary - then get this and install it. I am in love with the difference it makes. I know it seems silly in theory, and it's a lot of money for what it is, but I really like mindlessly pushing the clutch to the floor and getting quick, consistent engagement.
enjoyminutemaid is offline   Reply With Quote
Old 01-31-2014, 11:59 AM   #2
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
DIY - Easy clutch grab adjustment (~10 mins)
Dustin is offline   Reply With Quote
Old 01-31-2014, 12:05 PM   #3
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
I'm with you on the "mindless" part!
Did you adjust your clutch pedal height in the process or it wouldn't work because of not enough pedal travel (low height + bumper)?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 01-31-2014, 03:50 PM   #4
enjoyminutemaid
I've adjusted the clutch many times, also tried removing that helper spring. Adjusting the pedal only raises or lowers how high the pedal comes up when not being pushed down, reducing travel from the front end basically. This clutch stopper changes how far down you can push the pedal in, reducing travel from the back end.
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
jcw99 (11-09-2018)
Old 01-31-2014, 03:55 PM   #5
mid_life_crisis
Drives: FR-S 10 #103 AT
In the Speed3 I had there was a convenient place to put in a bolt under the pedal and do the same thing for a few cents. It is a lot easier than training your foot to not go all the way to the floor. Especially when you are ripping through the gears.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
ja1217 (03-05-2014)
Old 01-31-2014, 04:05 PM   #6
enjoyminutemaid
Exactly. That's basically what this is, but it has a nice plastic or rubber piece so you're not pushing metal against metal.
Old 01-31-2014, 04:13 PM   #7
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Pic? Link?
EvilBeaverFace is offline   Reply With Quote
Old 01-31-2014, 04:23 PM   #8
tbertran
tbertran's Avatar
That's definitely attractive to me but I also adjusted the pedal because, by default, it stands too high to my taste (and I sport a healthy size 12!)
Old 01-31-2014, 04:44 PM   #9
enjoyminutemaid
Originally Posted by EvilBeaverFace View Post
Pic? Link?
Comes up if you Google it, first link. I bought it from 86zn6.
Old 01-31-2014, 05:13 PM   #10
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
http://www.86industries.com/WORKS-Ki...Stop_p_70.html
Copy and pasting the link into a post seems to have worked on my machine
rupert is offline   Reply With Quote
The Following 4 Users Say Thank You to rupert For This Useful Post:
deucethemoose (02-01-2014), EvilBeaverFace (01-31-2014), ProjectD (02-02-2014), SkAsphalt (03-03-2014)
Old 01-31-2014, 05:26 PM   #11
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
looks like a $5 trip to home depot to me...
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-31-2014, 05:34 PM   #12
enjoyminutemaid
True. I just didn't feel like spending time driving to the store and trying different bolts.
Old 02-01-2014, 10:45 AM   #13
psyclone07
psyclone07's Avatar
Drives: WRB BRZ
Exactly. My friend did exact same thing to his e46 m3. Home Depot should have what you need.
psyclone07 is offline   Reply With Quote
Old 02-01-2014, 11:27 AM   #14
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
The hole for that clutch stop is for a #8 size thread.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
u/Josh (03-03-2014)
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
DI seal improved material radroach Engine, Exhaust, Transmission 21 01-16-2014 12:42 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
