Old 08-01-2013, 12:28 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
Exterior led strip courtesy light?
Has anyone though about doing this or has done it? Like have a led strip on the exterior underneath the car by the door and wire it to the done light. Not sure if it'd be tacky or look good. Pics and or opinions would be awesome. Thanks!
ft86me is offline   Reply With Quote
Old 08-01-2013, 01:57 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I did that in my wife's trunk. Mustang trunks have terrible lighting. The LED strips are dirt cheap on ebay and weather proof. Coated in rubber. As long as you protect the leads going into the door card and use a very solid tape/adhesive, this would work well. I have a lot of LED left over, maybe I'll try it. Get a small controller as well so you can change the color and pattern if you care to.
http://s1174.photobucket.com/user/mi...?sort=3&page=1
I have these same LED's around the steps on my back deck, been there for three years now without issue.
michaelahess is offline   Reply With Quote
Old 08-01-2013, 02:01 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
Oh wow that's awesome. Wonder if it can be done. Well I'm sure it can be but if it'll look good or not. I want them to illuminate the ground so I'm sure there is a decent spot to stick em on to. Wire to the done and it'll slowly fade out which is what I want. I wouldn't need to change colors. Just white would be good
Old 08-01-2013, 03:50 PM   #4
ft86me
ft86me's Avatar
Drives: 2013 FRS
What size sway bars you guys running?
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
D.I.Y. - BRZ courtesy door light bulb change joergasm DIY (Do-It-Yourself) Guides 24 09-13-2018 02:06 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
LED WHITE COURTESY FOOT LIGHT- Group Buy F-T Exterior Parts - Lighting 2 03-04-2013 04:59 AM
