Old 04-14-2013, 06:08 PM   #1
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Help with suspension/tire size combination...
Mods, please lock/delete.
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 04-14-2013, 06:26 PM   #2
donutfilling
donutfilling's Avatar
Drives: frs
245/40-18 is pretty tall for the rear. I think you should run 255/35-18 ideally or if you want 245/35-18
Remember that because you are differing from the stock diameter so much with those other sizes that not only is your odometer going to be slightly off, but you will have slightly different mechanical leverage putting power to the ground (like a final gear ratio).
donutfilling is offline   Reply With Quote
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 08:09 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
Wheel and Tire combination? HillCountryGuru Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 03-05-2013 12:08 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
