Old 01-16-2014, 10:46 AM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Car/Ambient temperature to log data
So pretty basic question. What temperature is ideal for the car to be at before logging data? Reason i ask is because with the winter here, it takes much longer for the cars to warm up than in the summer.
Summertime Ambient temperature is around 70-80 degrees.
Wintertime Ambient temperature is around 30-50 degrees.
Does the outside temperature really make a difference, or is all that matters is the car is warmed up, and if so, what is ideal?
Thanks for any info.
gdrider77 is offline   Reply With Quote
Old 01-16-2014, 11:21 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
I always go for oil temp over 80C but don't allow much over 100C, coolant temps should be fine by then. To me that's all I care about. Obviously keeping an eye on IATs for behaviour but not much else.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-16-2014, 11:59 AM   #3
gdrider77
gdrider77's Avatar
Sounds good to me. I usually log around 80-90, so sounds like we are on the same page. It seems like the car temp is much more important than the ambient temp.
Old 01-16-2014, 12:10 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
So long as you know the potential effects of differing IATs then the rest doesn't matter. Ideally for logging you want to keep ambient conditions as consistent as possible but we live in the real world. Logging at the same time of year should be good enough as air temperatures won't swing a huge amount. If you want to do changes and you haven't logged for 6 months etc, why not do a fresh pre-change log in the warmer/colder climates and then do the updates and re-log as necessary.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-16-2014, 12:36 PM   #5
gdrider77
gdrider77's Avatar
Whats the accepted range on our IAT? Any ideas? i tried to search, but IAT cant be searched...ugh.
Old 01-17-2014, 03:04 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Which tuning platform do you use? Just keep in mind big changes of temp can affect AFRs, it won't be massive but you may notice differences. Hot intake temps could make the car more prone to knock, but again it would have to be pretty warm. There's a table for timing corrections made against IAT that you can check to see what the OEM thought a good idea to pull timing. IIRC its 60/70c before anything happens.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-19-2014, 08:49 AM   #7
gdrider77
gdrider77's Avatar
Using ecutek. Thank for the info.
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Color Temperature FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 01-03-2014 11:19 PM
Ambient temperature's influence on horsepower BuBlake Engine, Exhaust, Transmission 40 04-10-2013 12:17 AM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 10:05 AM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
