Old 03-29-2013, 12:49 PM   #1
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Ambient temperature's influence on horsepower
With crazy Texas temperature shifts lately, I have noticed time and time again that my car runs substantially better and faster on cold days. Maybe the effect is more exaggerated because I have a short ram intake that also sucks in engine-bay air... It's really disheartening; One day I feel like I have a fast car, then it feels slow the next, all because of the ambient temperature. Just wondering if anyone else is experiencing this that has a stock intake or a CAI.
Also, why isn't there some way to cool the intake like with a small refrigerator or something? My guess is that nothing can keep up with the amount of air the engine is sucking in.
(Braces for impact )
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 03-29-2013, 12:52 PM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Don't know about the refrigerator bit, but you could get a nitrous kit. Same principle in theory.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
BuBlake (03-29-2013)
Old 03-29-2013, 01:09 PM   #3
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Get a ScangaugeII and it will tell you what your intake temperature is. I have the Perrin intake and I run around 3 degrees hotter in my intake than the outside air.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Old 03-29-2013, 01:26 PM   #4
ScionFrsFan
Not sure I noticed that yet...maybe in the summer? I wont get a short ram like injen tho, sticking with drop in. I had a K&N short ram on my celica and it always would get heat soaked in the summer heat...It was awful.
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
The Following User Says Thank You to ScionFrsFan For This Useful Post:
Old 03-29-2013, 01:29 PM   #5
reeves
I have FA20club's CAI and it keeps my intake temps within 2-4 degrees of the outside air temps when I'm on the go. Summer's coming up so we'll see how it handles hotter temps..
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
Old 03-29-2013, 01:29 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
Simple solution would be a new or stock intake, short ram/hot air intakes are notorious for heat soak.
The power loss from running a compressor to have an evaporator cool your intake charge would not even begin to offset the small gain from cooler air. In fact the moisture you lose from the air condensating on your evaporator might result in a less dense air charge... Or was it the more moisture the less oxygen is in a given amount if air....
Go back to stock airbox and see how it works out IMO
Old 03-29-2013, 01:50 PM   #7
BuBlake
BuBlake's Avatar
Never heard of that. I figure that mine must run at least 10 degrees hotter than ambient after sitting at idle. I'll pick it up if it's cheap, but I will probably just re-install my stock intake and buy a drop-in.
Old 03-29-2013, 01:56 PM   #8
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Better yet, instead of a ~$160, wired accessory, you can get a $20 wireless bluetooth OBDII adapter and the Torque app for any Android phone (I think iPhone has some kind of app too). Same thing (and more, actually) for 1/8 the cost.
https://play.google.com/store/apps/d...l.torque&hl=en
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
The Following 2 Users Say Thank You to cfusionpm For This Useful Post:
Bg8780 (04-09-2013), TouchMyHonda (04-09-2013)
Old 03-29-2013, 01:59 PM   #9
BuBlake
BuBlake's Avatar
I didn't think about the moisture; that's probably the primary reason that it cannot work. I would just assume running an air vent from the existing ac unit into the airbox? hehe...
But regardless, isn't that exactly what an intercooler does in a turbo setup? Why can't we put intercoolers in our NA cars? I know someone is about to tell me to just use the search... haha
Old 03-29-2013, 02:08 PM   #10
BuBlake
BuBlake's Avatar
Okay, just did a search to answer my own question, basically.
An intercooler is conventionally just a heat-sink that will do nothing more than help the hot air from the turbo come closer to ambient temperature. It is not a refrigerator.
As for the air vent from the ac compressor, I'm still a bit confused, but I think it may be a bit too moist.
Old 03-29-2013, 02:10 PM   #11
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Can Torque show IAT and Oil Temp? I see outside air temp and coolant temp in your pic.
Chewie4299 is offline   Reply With Quote
The Following User Says Thank You to Chewie4299 For This Useful Post:
Old 03-29-2013, 02:12 PM   #12
BuBlake
BuBlake's Avatar
Awesome. I see many of those for cheap on Amazon. I do have an iPhone, so hopefully they make some equivalent app for it. (Otherwise I may be switching to droid... That looks interesting!)
Old 03-29-2013, 02:15 PM   #13
cfusionpm
I use Torque with this adapter ([ame="http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-compatible/dp/B005NLQAHS/ref=sr_1_3?ie=UTF8&qid=1364580829&sr=8-3&keywords=OBDII"]BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive[/ame]) and it works great. Quick read and response times, well priced, gets the job done. Your OBDII sensor plug is under the steering wheel, just above your gas pedal.
Some of the long term averages like MPG and other calculations aren't as accurate because they only factor when the app is running. But any of the instantaneous readouts are straight from your ECU (or calculated using values straight from the ECU). Really sweet little app.
The Following User Says Thank You to cfusionpm For This Useful Post:
Old 03-29-2013, 02:24 PM   #14
BuBlake
BuBlake's Avatar
I use Torque with this adapter (BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive) and it works great. Quick read and response times, well priced, gets the job done. Your OBDII sensor plug is under the steering wheel, just above your gas pedal.
So this will show intake temperature? I do not see it in the picture, just an ambient.
Who says we need more horsepower? LeeMaster Scion FR-S / Toyota 86 GT86 General Forum 36 01-11-2013 11:05 AM
Bolt on 6 horsepower for about $50. MillersOilsUS Engine, Exhaust, Bolt-Ons 29 01-10-2013 08:53 PM
6 horsepower, 4 lb-ft from an oil change MillersOilsUS Mechanical Maintenance and Tools 1 01-03-2013 11:21 AM
ft86.com has some serious horsepower! MrBRZ Off-Topic Lounge [WARNING: NO POLITICS] 2 03-22-2012 07:45 PM
