Old 12-29-2013, 09:48 AM   #1
FRSure
Drives: Toyota
Color Temperature
Just a question, what color temperature are the stock oem bulb?
Low beam h11
High beam 9005
Foglight h11
FRSure is offline   Reply With Quote
Old 12-29-2013, 01:08 PM   #2
Tsungfai
Tsungfai's Avatar
Drives: 2013 Scion FR-S Raven
More then likely its 4300k for all three.
Tsungfai is offline   Reply With Quote
Old 12-29-2013, 01:34 PM   #3
FRSure
Drives: Toyota
Wouldn't the OEM have lower color temp than others? Because I'm planning to get Sylvania silverstar ultra ZXE. And I wonder how much of a diff it would make.
Old 12-29-2013, 01:42 PM   #4
Bushman7140
Drives: 2013 FRS M/T Firestorm
It's much closer to a 5000k color temp. It's definitely a whiter lite than stock, but less bold than HID's, if that makes sense?? They'll still have the yellow look with the DRL's however so keep that in mind before you swap out the high beams.
Bushman7140 is offline   Reply With Quote
Old 12-29-2013, 01:52 PM   #5
FRSure
Drives: Toyota
Got ya. I'm only swapping the low and fogs as I never use high. So basically OEM is 4300k while those Phillips crystal vision and Sylvania silver star ZXE are about 5000k right?
Old 12-29-2013, 01:54 PM   #6
Bushman7140
Lets see of this works... Trying to upload from an iPhone. The wall shot of the cutoff is too large to upload... These are low beams..
Old 12-29-2013, 02:44 PM   #7
FRSure
Drives: Toyota
What bulb is that?
Old 12-29-2013, 04:18 PM   #8
Bushman7140
That's the sylvania is ZXE's... It's the white light you're seeking, just not as bold as HID's.. Unless you're wanting to stick with the stock lighting, I'd go HID's. You can find some solid kits for just a few dollars more.
Old 12-29-2013, 04:33 PM   #9
FRSure
Drives: Toyota
I prefer sticking to Halogen. In your opinion how much is a difference between OEM halogen and the ZXE? Does it shine farther than OEM? Is the color very notcible or just slight? - compared to oem
Because I'm thinking of getting yellow fog and white low beams.
Old 12-29-2013, 05:04 PM   #10
Bushman7140
I went with it purely on a cosmetic basis, I literally had 150 miles on the car when I swapped the OEM. There is no noticeable difference for what I'm used from any of your standard Toyota halogens. It's brighter, but I can't really comment on distance. The color is definitely a big difference between OEM.
Old 12-29-2013, 05:16 PM   #11
FRSure
Drives: Toyota
How many miles u have on the car now? I seen ppl with zxe bub burning out under 6 months.
Old 12-29-2013, 05:34 PM   #12
Bushman7140
3k a lot of night driving coming up on 2 months..
Old 01-03-2014, 07:18 PM   #13
KI_ZN6
KI_ZN6's Avatar
Low beam h11
High beam 9005
Foglight h11
The factory bulbs are 4300k. One of the main benefits of upgrading to HIDs is you get 3 times more usable light and plus you get the choice of keeping the factory colour if you wish, that is, install a 4300k HID kit so that you are maximizing your visibility at night. We sell alot of the 6000k HID kits because it serves as a cosmetic modification while significantly improving visibility compared to the factory light bulbs. Talk about function and form
KI_ZN6 is offline   Reply With Quote
Old 01-03-2014, 07:47 PM   #14
FRSure
Drives: Toyota
Even the H11 halogen can produce 4300k? It looks pretty yellow...
I'm just afraid hid will blind on fogs reflector. And bad cut off with halogen projector.
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Looking for a Subaru BRZ in WRB Color for color-match. Will Compensate Roof Spoiler Beat-Sonic Southern California 19 03-09-2014 07:31 PM
Intake Air Temperature sw20kosh Forced Induction 18 06-19-2013 04:49 PM
GT86 Headlight Color Temperature? PelzerC Scion FR-S / Toyota 86 GT86 General Forum 3 03-29-2013 01:17 AM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 10:33 PM
