Old 01-12-2014, 10:26 PM   #1
vanetix
vanetix's Avatar
Drives: Subaru BRZ - GBS
Engine cut out/stall followed by CEL
Hey guys/gals,
I warmed the car up as usual leaving a friends house tonight, and then slowly coasted (clutch in) to the end of the cul-de-sac to turn around. My engine then cut out and stalled, and failed to start after hitting the start button right after the stall. Then I waited 5-10 seconds and it started, but was very rough at first and lit up the CEL. It sounded like the engine wasn't getting fuel, but I had been idling for 3-5 minutes prior to that, and also had just over 1/2 tank of gas.
Anybody else had something similar? I will be pulling the code with a friends reader tomorrow, but wanted you folks insight and/or experiences in the meantime.
vanetix is offline   Reply With Quote
Old 01-12-2014, 10:34 PM   #2
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
Yeah, I had that problem before, and my car is automatic. lol You might want to go back to the dealer to get your ECU flashed.
TOTO_86 is offline   Reply With Quote
Old 01-13-2014, 12:09 AM   #3
humfrz
Yep, good idea to read the code.
Maybe it just "hiccupped" and it righted itself and it will be OK.
Keep us posted.
humfrz
Old 01-13-2014, 11:21 AM   #4
vanetix
vanetix's Avatar
Thanks for the replies, it looks like it cleared itself this morning. Seems like it was some type of failsafe that might have triggered, I'll post any codes I get later today or tomorrow morning.
Old 01-16-2014, 11:51 AM   #5
vanetix
vanetix's Avatar
The code that was thrown was P0108, which is a high intake pressure reading from the MAP sensor. Not sure why, I do have a Perrin intake tube, but stock intake. I have checked all the hose clamps, but all are tight and there are no leaks.
Stall/Torque Converter DeOppressorLiber Engine, Exhaust, Transmission 44 06-12-2014 12:00 PM
1st gear + 0 Acceleration: Will not stall TIE Pilot Engine, Exhaust, Transmission 40 10-19-2013 01:18 AM
Stall in high G turn/oversteer spin DR J Engine, Exhaust, Transmission 23 06-04-2013 01:54 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Partial Stall's WRB Partial Stall Member's Car Journals 3 06-07-2012 06:53 PM
