Drives: TIE interceptor; BRZ13
1st gear + 0 Acceleration: Will not stall
Do a little experiment and the car will not stall: Standing still, put 1st gear and gently release the clutch, don’t step on the gas, your car will start rolling. (Default ~700 RPM will not let engine stall)
Also if you are driving slowly, you can shift down from 2nd to 1st and after releasing the clutch do not step on any of pedals. The car will continue in a slow roll and again not stalling.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
So you're talking about taking off from a dead stop without using the throttle?
Drives: white Sport-tech
yes sir.
Weight Nazi
Have you ever found a car that couldn't do this?
Well last time i drove a manual was 1997 and a pickup truck.... so that is that. Sorry for sharing then. lol.
Weight Nazi
Yeah, I'm pretty sure all cars can do this. That's why I wasn't sure if I was reading it correctly or not. You could probably even do this in 3rd gear if you babied it enough. And you could probably take off in 6th gear with some gas. Not recommended, though.
Try holding the brake in and test your theory.
SLO NO MO
Every manual I've ever driven was able to get off to a rolling start with the clutch eased in from a standstill without applying any gas. On the other hand, I've stalled every one of these cars inadvertently by releasing the clutch too fast or if I didn't apply enough gas while starting on an incline.
I've often used this when teaching someone to drive stick - forget the gas at first and learn where the clutch contact point is, then learn how much you have to ease it out to keep the car going forward. |
#10 | |
#11 |
Drives: 13 BRZ Limited 6MT GBS
Yup, that's the best way to go. Otherwise they never learn where the clutch bites, and just rev it to 3k while letting the clutch out. Once you learn where it bites, you can just give the throttle a little blip there to speed up the process, with less wear and tear.
#12 |
Drives: Dodge Patitas
#13 |
Drives: FR-S 6MT
Why is that an experiment? I do this almost all the time..
I use little to no gas when starting out.. Used to driving big V8's.. Works for this tiny motor too... But takes some conscious effort To do it smoothly.. Be one with the machine.. |
#14 |
Drives: 2013 FR-S whiteout
This is like the Fox News of threads.
| acceleration thump | mid_life_crisis | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-10-2013 09:19 PM |
| Stall in high G turn/oversteer spin | DR J | Engine, Exhaust, Transmission | 23 | 06-04-2013 01:54 PM |
| Does the A/C cut off upon hard acceleration? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-26-2013 09:31 AM |
| Partial Stall's WRB | Partial Stall | Member's Car Journals | 3 | 06-07-2012 06:53 PM |
| Acceleration | Axel | Other Vehicles & General Automotive Discussions | 0 | 02-10-2010 06:56 PM |
