Old 11-15-2013, 07:29 PM   #1
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
Stall/Torque Converter
Has anyone changed, modified or tuned their Torque Coverter? I have the FBM Stage 1 Premium Turbo set up and not being able to power brake to spin some tires is a little bothersum when a Cobra pulls up and burns his tires! Then the light goes green he pulls a car length then I fly by them going into third.
The Trypticon Transformation in Progress!
DeOppressorLiber is offline   Reply With Quote
Old 11-15-2013, 08:02 PM   #2
ramiram1984
Drives: 2016 STi DGM
This ain't no 60/70s American muscle car foo
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 11-15-2013, 08:24 PM   #3
Ross
Drives: 85 corolla gts
I am sure you could have it done but with not being able to access and modify the transmission parameters it could cause a lot of issues. Same concern I have with modding the valve body.
Ross is offline   Reply With Quote
Old 11-15-2013, 08:26 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
South Side Performance was supposed to be offering all kinds of stuff for the auto...I'm not really sure what happened with that...
Old 11-15-2013, 11:19 PM   #5
DeOppressorLiber
Interesting....maybe the foo should do some research. I call people like you Ignorant! To cure your case of ignorance, their is a Toyota Service Bulletin that in mechanical terms" which I dont have time to teach you" is a weekness of the vehicle. Just a little knowledge for you though...if one day you pay someone to put a turbo on your car, no you would need a SC because it doesn't require as much mecbanical knowledge. Then maybe you will take the time to learn about Stall and Torque Coverters. On these cars they are set at around 2200 rpm, thus not letting the turbo spool and release the Torque to the transmission to spin tires.
If you dont have anything constructive to say about the Topic, then get the hell off the forum and go kick some rocks!
Old 11-15-2013, 11:38 PM   #6
DeOppressorLiber
The only issues I have had in the past was dialing them in for the specific turbo and you definitely will want a coolant system added to the trans fluid. Once they where tuned, they ran great as long as you dont fo crazy and above 4k. Unless you have a funny car on the track doing wheelies down the 60!
Old 11-16-2013, 01:30 AM   #7
Fast_Freddy
Drives: Passat
I have no problem power braking my mildly modified AT FRS. Did you forget to turn off the TC? Maybe you're pushing the brake pedal too hard?
If you still want to modify the trans/TC, try calling Level Ten and/or Import Performance Transmission.
Fast_Freddy is offline   Reply With Quote
Old 11-16-2013, 10:32 AM   #8
DeOppressorLiber
I never drive it with the the TC on. It will do it sometimes and then other times go straight to 2k and the boost blow off!
Old 11-16-2013, 10:41 AM   #9
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I brake torqe my auto all the time. its how i launch in autocross. you just have to modulate the brake while you are doing it and you can spin the tires in place.
Now if you are talking about trying to rev to 4k sitting still and no tires spinning thats a different story. there is a thread in the autocross section where we talk about launching the automatic
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 11-16-2013, 10:47 AM   #10
DeOppressorLiber
No revving in a race. I just want to warm my tires with some spin. It will do it every now and then. What do you mean by modulate the brake? This is what happens. The TC and all is off, I press the brake and floor it, engine revs to around 22-25k and stops their! I let off the gas and the boost comes out the BOV!
Old 11-16-2013, 12:30 PM   #11
feldy
feldy's Avatar
You have to modulate the brake you can't just stand on it. You have to do about 75 percent brakes then mash the gas. I have go pro footage of me doing in that thread just go check it out and get back to me.
Old 11-16-2013, 12:32 PM   #12
feldy
feldy's Avatar
It just hit me you started that thread that I posted in. Posted a few videos in it. http://www.ft86club.com/forums/showthread.php?t=48499
Old 11-16-2013, 12:51 PM   #13
Hardrock4445
Hardrock4445's Avatar
It just takes a certain feel. Car can brake stand like crazy on stock power. Should be able to with minor boost at those RPMs.....
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 11-16-2013, 01:54 PM   #14
feldy
feldy's Avatar
This. I can do it on stock power with big wide sticky tires. It took a lot of practice to get it down though.
1st gear + 0 Acceleration: Will not stall TIE Pilot Engine, Exhaust, Transmission 40 10-19-2013 01:18 AM
Header with Catalytic Converter ScionFR-S Engine, Exhaust, Transmission 21 09-21-2013 12:29 PM
Catalytic Converter question! destinharper Engine, Exhaust, Transmission 4 08-27-2013 09:56 AM
Stall in high G turn/oversteer spin DR J Engine, Exhaust, Transmission 23 06-04-2013 01:54 PM
Partial Stall's WRB Partial Stall Member's Car Journals 3 06-07-2012 06:53 PM
