Old 01-10-2014, 08:39 AM   #1
swift996
swift996's Avatar
Engine Sensor OBD II Guide
Hey guys, I thought it might be a good sticky to get a list of all the sensors and what the read from the factory ECU. I thought it would make reading logs easier for everyone. Does anyone have this or care to provide some resources?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-10-2014, 09:16 AM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
If you're talking elm327/OBDII PIDs like Torque and programs like that, there's PIDs in the Torque App thread.
If you're talking Tactrix/CAN bus logging, there's a great work-in-progress in the EcuFlash thread but this is a bit more tricky as the memory addresses depend on which ROM you have on your car.
AdrianG is offline   Reply With Quote
Old 01-10-2014, 09:54 AM   #3
jamesm
yeah it really depends on what you're using to log, since different software packages access different params. there's the normal obd2 pids, but most of them aren't useful for tuning. all the good stuff requires access to extended params (with ecutek, brzedit, etc.)
there's also some difference in naming between the different software packages that could be made clearer with a sticky.
Old 01-10-2014, 01:46 PM   #4
swift996
swift996's Avatar
I was looking at my EcuTek and Torque logs and thought to myself what's the difference between Knock Correction, Learned Knock Correction, the various A/F measures, etc. So I was thinking from a perspective of what it is and where/how it's measured. Does that make sense?
Old 01-10-2014, 04:48 PM   #5
arghx7
Drives: car
Please be more specific. What are exactly are you comparing between the two programs?
You also have to be very careful comparing values from ECU RAM versus values taken from a request across a government-legislated OBDII PID. The sample rates get real screwy on OBD II, and calculations are done according to an industry standard rather than Subaru internal software conventions.
arghx7 is offline   Reply With Quote
ECU and Engine Tuning Reference Guide swift996 Software Tuning 140 11-02-2022 12:18 AM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
