Old 01-09-2014, 03:23 PM   #1
mike the snake
Deatshworks 65 fuel pump install questions
My shop is installing the direct-fit D65 fuel pump.
I've read about install issues, just wanting to confirm the number of O-rings needed and hopefully find anything else I need to know so things go more smoothly that they have so far.
I read someone used 4 O-rings, can anyone confirm this?
Thanks for any help.
Mike
Old 01-09-2014, 03:27 PM   #2
mike the snake
I was given the link to the install thread, THANKS, I think that will have all the info my shop needs.
Old 01-09-2014, 03:27 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Four O rings or the white spacer and two O rings. They key is that the FP casing closes really tight (without breaking of course.)
If you don't make sure about it, you will be loosing fuel pressure and going lean.
Old 01-09-2014, 03:27 PM   #4
MAPerformance
Drives: Asphalt FRS
We used just two O-rings. Don't forget to use the OEM spacer. That needs to be installed on the DW pump. The only issue installing is you need to cut the bottom clip that holds the OEM pump in since it sticks out too far.
Edit: Sprtsguy83 beat me to it
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
Sportsguy83 (01-09-2014)
Old 01-09-2014, 03:43 PM   #5
mike the snake
Thanks!
My shop had issues with the FB pump, first no pressure, then it seems to work intermittently with only 10lbs pressure when it did work. Now, we're installing the D65 pump and I want to make sure it gets installed correctly.
Thanks for the help.
mike
Old 01-09-2014, 03:48 PM   #6
Sportsguy83
Drives: Limited BRZ
Originally Posted by mike the snake View Post
Thanks!
mike
I am sure it was because white space and only one O ring because 2 o rings do not allow the pump canister to close. Fittings those bigger pumps can be done, but require 3 O rings and no white spacer. But thats another story, I recommend the white spacer and 2 O rings for the DW65 and you will be good.
Old 01-09-2014, 07:46 PM   #7
mike the snake
I checked today, and it seems they got the FB pump to work today, they had the O-rings stacked wrong, needed to add another O-ring and we now have good fuel pressure.
They had also reported that the pump was turning on and off, not sure if that was maybe because it couldn't reach priming pressure or what, hopefully it'll work as it should and they'll get on to tuning!
I can't wait!
The Following User Says Thank You to mike the snake For This Useful Post:
Old 01-09-2014, 08:02 PM   #8
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Thats great, keep us posted
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
DIY: Deastchwerks 265c Fuel Pump Install xxscaxx DIY (Do-It-Yourself) Guides 35 01-24-2018 07:23 AM
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
PSA: Tips on what needs to be payed close attention on Fuel Pump install Sportsguy83 Engine, Exhaust, Transmission 34 04-25-2014 11:24 PM
DIY: Fuel Pump Install-Video Ny Brz DIY (Do-It-Yourself) Guides 2 09-12-2013 10:59 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
