| DIY (Do-It-Yourself) Guides For all DIYs. |
Hella Flush
Drives: 2013 SWP BRZ
DIY: Fuel Pump Install-Video
Hey guys, just wanna post this video that Toni from FA20club posted on Youtube, he said it would be okay to post it for him. I hope you guys find this helpful, be sure to like and comment on his video if you find this helpful.
[ame="https://www.youtube.com/watch?feature=player_embedded&v=GLTP7KxgjPs"]FA20CLUB FR-S BRZ Fuel Pump Install Guide - YouTube[/ame]
Seems Legit
Drives: Toyota
One thing worth mentioning as I ran into this issue today.
You may run into an issue with once you put the sleeve and 2 O-rings on the new pump and the pump does not "click" back into place but you try to install the pump into the canister and you have a lot of resistance, don't force it. Take the pump back out and look for any "old" O-rings that may have come off while you were removing the old pump. The old pump is also held in by 2 O-rings so there is a chance when removing the old pump that an O-ring did not come out with the old pump. When you try to install the new pump, the additional resistance that you could be experiencing with the additional 3rd O-ring (2 new, 1 old). Just take your pic tool and pop out the old O-ring. That should allow the new pump with the sleeve and 2 O-rings to "click" into place and you can proceed with finalizing your install. One last tip, when reinstalling the canister into the vehicle, remember the lip of the canister gasket goes inside of the tank. If you simply place it on top of the tank, the screwing lid will never grasp the threads.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
Seems Legit
Drives: Toyota
And one more thing. A hiss coming from the drivers side after install of the pump is perfectly normal, especially for DW (DeatschWerks) pumps. I had the same noise in my tC. If you turn down your radio and press the throttle, you'll hear the pitch of the hiss increase with the RPM. If you get this just know...it works!
| Tags |
| fa20club.com |
| DIY: Deastchwerks 265c Fuel Pump Install | xxscaxx | DIY (Do-It-Yourself) Guides | 35 | 01-24-2018 07:23 AM |
| Fuel pump upgrade install (Visconti 290lph) | jet86 | DIY (Do-It-Yourself) Guides | 44 | 01-04-2018 07:56 PM |
| PSA: Tips on what needs to be payed close attention on Fuel Pump install | Sportsguy83 | Engine, Exhaust, Transmission | 34 | 04-25-2014 11:24 PM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
