Old 01-05-2014, 02:45 PM   #1
jonbonazza
Window switches not working right after battery swap
Okay, so the other day, I swapped my batter out for a Lightweight Braille battery (11lbs, using the FT86SpeedFactory kit, if it matters). Ever since then, I have noticed that from the driver's side, I can roll the driver's side window up and down, but the "auto down" and "auto up" features don't work. I have the hold the button the whole time each way. The switch for the passenger's side window on the drivers side doesn't work at all! On the passenger's side, the switch for the passenger side window works, but again, it must be done manually both ways.
Is this something to do with swapping the battery (can't imagine how it could be, but that's the only thing I did that day) or is it something to do with the cold whether?
jonbonazza is offline   Reply With Quote
Old 01-05-2014, 06:06 PM   #2
humfrz
Just open the window and hold the button down for a couple of seconds after it has opened. Then roll the window up and hold the button for a few seconds after it has closed.
That ought to re-set the auto up & down.
Yep, that can happen after the battery is disconnected.
humfrz
Old 01-05-2014, 06:18 PM   #3
jonbonazza
humfrz
That did it. Thanks!
Sent from my Nexus 4 using Tapatalk
Old 01-05-2014, 07:12 PM   #4
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
humfrz
I must ask. Is that in our owners manual, Humf?
Wolfking is offline   Reply With Quote
Old 01-05-2014, 08:20 PM   #5
humfrz
I first read it in the owners manual for my wife's 07 Saturn. That happened to her car a couple of years ago, after I swapped out the battery.
I just checked, yepper it's in the FR-S manual also (page 53) ....
humfrz
Old 01-05-2014, 08:22 PM   #6
jonbonazza
Well, I probably would have RTFM if I realized it was normal. lol
Old 01-05-2014, 11:48 PM   #7
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
I had no clue either. Now WE know! Your avatar is killing me ROFL!
Old 01-06-2014, 12:19 AM   #8
humfrz
............. Your avatar is killing me ROFL!
....... ....... me too. Every time I see it, I watch it do it's whole thing ..... OK, so I need a life .....
humfrz
Old 01-07-2014, 09:51 AM   #9
jonbonazza
I'm not gonna lie. every time I see it I usually watch it at least twice. lmao
Old 01-10-2014, 02:50 PM   #10
DoopaTroopa
Kato
DoopaTroopa's Avatar
Drives: The Black Beauty
If you live in a cold area you might run into the same problem with the auto up/down not working due to ice and it sticking, but the solution mentioned above fixes it all the same. I had to go a step further because it got stuck in the down position on a 5° day so I had to remove the negative terminal for while before I could roll the window back up to reset the motors.
DoopaTroopa is offline   Reply With Quote
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 01:25 AM
Passenger window not working after rain reset does nothing Mike86 Issues | Warranty | Recalls / TSB 0 08-30-2013 08:18 PM
Bass Rattles Driver Side Window Switches.... jadewbj Issues | Warranty | Recalls / TSB 14 05-19-2013 12:42 PM
Simple Shut Window Feature Not Working on Driver's Side Gimagination Issues | Warranty | Recalls / TSB 21 05-08-2013 11:59 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
