Drives: 2013 BRZ Limited
Fuel Filler Neck Problem
I went to fill my tank tonight and something didn't seem right. I thought there was a piece in the filler neck that gets pushed down when you put the fuel nozzle in. Its hard to explain but I attached a picture of what it looks like. I couldn't find a single picture of what the filler neck should look like without the gas cap on. How concerned should I be about this? I will be contacting the dealership in the morning.
#2 | |
Looks about the same to me. I wouldn't worry. |
#3 | |
Drives: br zed
Will look at my gas filler tomorrow, just wondering if this might be an issue with my car. I topped off from 3/4 to full last Sat night because I found cheap ass 93. Got in the car to reset the trip, mpg etc and noticed the gauge still said 3/4. Drove home 25 miles, no change. Shut the car off, pulled the batt cables and it still was at 3/4. Going to run it all the way down and see if it fixed itself. |
#4 |
Drives: 2020 DGM BRZ Limited
Reflash or stock? I had a similar problem with a EcuTek tune, ran the car for a day and went to top it off - gauge reset like it should. Also - do you continue to fuel after the auto shut off at the pump happens? I've read that can screw with things too..... HTH.
| The Following User Says Thank You to mikalem For This Useful Post: | Bad Habits (01-01-2014) |
#5 | |
Drives: WRB BRZ, Monte Carlo SS
| The Following User Says Thank You to cjsporl1996 For This Useful Post: | Bad Habits (01-01-2014) |
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Seems to be an ECU problem if you fill up before 1/4 down or so. It's been covered here before somewhere.
Run it down below 1/2 and it should reset eventually. Topping up tends to give it fits.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Bad Habits (01-01-2014) |
#7 | |
Drives: BRZ DGM Limited
Ya..mine did it once too when I filled up at 3/4 tank. Gauge did not come up but it corrected itself. Seems to be "normal" for these cars. These quirks are what make the twins so special! |
| The Following User Says Thank You to BRZnut For This Useful Post: | Bad Habits (01-01-2014) |
#8 | ||||
Drives: br zed
Thanks for the replys. I hadn't even searched it as I figured it was a fluke and was just going to run it down over the week and weekend if the weather was nice and disco the battery if needed. |
| Grimmspeed Oil Filler Cap | SilentMike | Engine, Exhaust, Bolt-Ons | 3 | 10-07-2013 10:37 AM |
| Fuel Gauge problem | adan | CANADA | 2 | 09-24-2013 11:12 PM |
| AFR Problem (maybe Fuel Pump installation bad) | whitefrs | Engine, Exhaust, Transmission | 37 | 08-30-2013 02:36 PM |
| For Sale: TRD Oil Filler cap | Panman | Australia Classifieds | 4 | 04-13-2013 07:22 PM |
| Fuel Filler is on the Right!! | Guaruja | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-01-2012 05:55 PM |
