Old 11-27-2013, 11:09 PM   #1
cycleboy
Drives: 2013 Scion FR-S - Argento
Door armrests
Tried a few searches and didn't turn up anything about this, so here's my thoughts on something I discovered today. I'd call this an issue I'd like to solve.
I've had my car for ~7 mos. and often times on the highway my right arm ends up sitting on the tunnel behind the e-brake and the left hand is on the wheel. This puts my left elbow on the driver's side door armrest.
I noticed today that there's a bit of a divot in that armrest from my elbow. I moved my arm for most of the drive home to see if it went back to normal, but it didn't. I'll check again tomorrow.
My guess is the padding is thin on the doors and not very high density, so it doesn't take much to permanently dent it and therefore make it not really padding anymore.
So my question is whether anyone has done anything to that area to put in thicker or higher density padding that might be a little more comfortable and longer lasting?
cycleboy is offline   Reply With Quote
Old 11-28-2013, 12:28 AM   #2
humfrz
Hi cycleboy .....
I had a miata for several years that had even harder armrests.
I fixed the situation with a pair of these.
They are easy to put on, are quite comfortable and lasted for at least 7 years and 88,000 miles. Maybe they are still going strong ..??
http://www.zetaproducts.net/05sciont...rmrestpad.aspx
humfrz
Old 11-29-2013, 08:16 PM   #3
cycleboy
I was thinking more about pulling off what's there and replacing the foam with either much higher density foam or maybe a gel. I haven't looked into how hard it is to pull the stock ones out to do something like this. As far as I've seen so far there aren't any aftermarket ones that offer more/stiffer padding that might stay padded longer.
Old 11-30-2013, 12:49 AM   #4
Gen
Drives: Scion FR-S
They are easy to remove and JPM coachworks could add higher quality padding pretty easily.
Gen is offline   Reply With Quote
Old 12-01-2013, 08:25 PM   #5
cycleboy
Cool, that's kind of what I had in mind as I have my eye on their various keen pads and other alcantara goodies. I figured someone who sells those types of products could do it, just wasn't sure about the ease of removal.
Old 12-02-2013, 09:46 AM   #6
JPM Coachworks
JPM Coachworks's Avatar
Drives: Honda S2000, Subaru STI
Send a message via AIM to JPM Coachworks
@cycleboy The most difficult part is removing the door card, which is more time intensive than technically difficult. Once the Door card is removed it is extremely easy to remove the Door Uppers. The Door Uppers that we build use a thicker, higher quality, open-cell medium density foam, as compared to the factory part, and as such, they will not lose their shape after use and exhibit longer life and comfort.
Here is an very helpful and descriptive thread from @Trojan_SC demonstrating the step-by-stepremoval of the door card. http://www.ft86club.com/forums/showthread.php?t=13583
V/R
Andrew
-JPMCoachworks.com
JPM Coachworks is offline   Reply With Quote
The Following User Says Thank You to JPM Coachworks For This Useful Post:
Trojan_SC (12-02-2013)
Old 12-02-2013, 01:01 PM   #7
Tromatic
A pillow is cheap, not permanent, does not look like some ugly afterthought, or cost an arm and a leg.
Tromatic is offline   Reply With Quote
Can opening door too wide cause damages to hinge/door? Weeber Scion FR-S / Toyota 86 GT86 General Forum 3 11-25-2013 10:07 AM
For those who don't have armrests in their FRS Frs x3 Scion FR-S / Toyota 86 GT86 General Forum 76 10-07-2013 11:40 AM
TRD door stabilizer and door sag.... Tromatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-25-2013 09:16 AM
8's in the door cruzinbill Electronics | Audio | NAV | Infotainment 2 01-26-2013 05:10 PM
