Old 11-02-2013, 04:52 AM   #1
ikeryder13
Drives: 2013 GBS BRZ
Building a motor before turbo?
Is this necessary? I see most guys run about 7 psi safely with 91 octane(ca)....
I'm looking into getting info about turboing... Is going turbo a better option then just building my motor?
I just hot my brz after trading in my 08 wrx and I miss the boost!
ikeryder13 is offline   Reply With Quote
Old 11-02-2013, 07:45 AM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
These motors respond very well to FI in their stock form. You can put on a turbo kit and build later. Careful for detonation because of the high comp motor, though.
Go with FullBlown.
slicktop is offline   Reply With Quote
Old 11-02-2013, 08:49 AM   #3
FullBlown
FullBlown's Avatar
Drives: Scion FRS
These motors can handle a decent amount of power with a proper tune. We recommend a built motor if you are trying to push over 400hp . Another reason to have the motor built is if you are limited to very poor gas.
It really all depends on your goals and what you intend to do with the car. Having a built motor will give you that piece of mind when you are beating the hell out of it.
FullBlown is offline   Reply With Quote
Old 11-02-2013, 08:53 AM   #4
mrk1
Drives: Sterling BRZ Ltd
Necessary, no. Does it make sense, sure. If you built the motor before FI then once you do get the turbo you don't need to worry. You would just have to make sure you don't go real low comp since it would become a dog probably. Lots of people are running FI on stock blocks but I know for me it would always be in the back on my mind that there is a potential failure.
I've considered building a spare short block but I think we are still so early in the improved internals game so I'd like to hold off for more options.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-02-2013, 11:36 AM   #5
ikeryder13
Thanks for all the info guys, full blown ur kit looks very promising, and definitely seems like a great option
Old 11-02-2013, 12:29 PM   #6
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Paul from @avoturbowould has just over a year on his car with the AVO kit. About 20k or so miles. As stated this car like the FI as for being in California and our gas, Paul has made several trips into California and tested different gas stations along the way. His last trip to subifest he ran 9psi on the stock setup with no problems.
DAMotorsports is offline   Reply With Quote
Old 11-02-2013, 04:46 PM   #7
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
If you have the cash and patients. I say do both at the same time so u don't pay for tuning twice. But if you put the turbo on first you going to want more power. But you get the feel of how the car drives on low boost. Either way boost puts a nice smile on your face.
Fabron757 is offline   Reply With Quote
Old 11-02-2013, 05:24 PM   #8
mike the snake
As stated there's only so much power you get with the stock internals. This however also coincides with the rest of the car being able to deal with the extra power.
If you go with a built engine and go for big power, you'll also need to build the car to handle that power, which means axles, clutch, and a bunch of other stuff.
You can get away with a turbo kit and tune on basically a stock car if you don't go too overboard.
Old 11-02-2013, 06:17 PM   #9
ikeryder13
What's the most miles anyone has on a turbo kit and stock motor before going boom lol?
Old 11-02-2013, 06:28 PM   #10
car_roll
Drives: Nuisance BRZ
In on this. Want to see how much a stock motor can handle in the long run.
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 11-02-2013, 06:54 PM   #11
mike the snake
AVO and King Tut I think both have 15-20,000 trouble free miles.
Old 11-02-2013, 07:13 PM   #12
ikeryder13
If worse comes I will take the kit off and dealer it lol
Old 11-02-2013, 07:48 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
I got more than 10,000 miles on mine without issues as well.
Running 7.5psi with 91 octane
And watercooled system
86_ZN6 is offline   Reply With Quote
Old 11-02-2013, 08:16 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. I have over 15,000 miles on the Full Blown kit all on 93 octane and @lexusb3 has just as many on his FA20Club kit but he changes boost and fuel between 93 and E85.
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
Best deal on Building motor Fabron757 Engine, Exhaust, Transmission 0 06-29-2013 09:20 AM
Anybody else thinking about buying crawfords rebuilt motor and turbo? Frsexxxy Forced Induction 21 05-29-2013 04:07 AM
