Old 06-23-2013, 04:26 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Installed steering, transmission an sub frame bushings, NVH question
so I recently had my mechanic install the TIC steering, kartboy transmission insert an whiteline rear subframe bushings. I'm impressed with the improvement in steering response and lack of drive line slop with the new additions. I do detect a hint of additional vibration in the steering wheel and seat at idle which I assume is normal. I only ask as others with similar mods mentioned no noticeable increase in NVH. is what I feel normal? Would urethane rather that solid steering bushings feel any different?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-23-2013, 07:13 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Yes you'd feel just a wee bit less NVH with the Whiteline vs the solid metal bushings. I have all the Whiteline bushings installed and at idle I barely feel anything, but there is a little. I feel more from the stick shift vibrating (I have the Whiteline trans insert and Perrin shift end bushing,) but it's very minor also. The biggest thing that will effect NHV will be engine mounts. The diff inserts will create additional noise but like everything else, it is slight. Nothing done to this car seems to be adding a ton of NHV as it seems to be a wonderfully engineered car compared to others I've owned. I have yet to put the engine mounts in but people say idle should be adjusted up a little with a tune, so I'll see what happens when the engine mounts, headers, and tune happen late next month.
stockysnail is offline   Reply With Quote
Turn In Concepts BRZ/FR-S SCCA LEGAL steering Rack Bushings Turn in Concepts Groupbuys 35 04-29-2013 11:57 PM
GROUP BUY - TiC BRZ/FR-S steering rack bushings Turn in Concepts Groupbuys 186 03-19-2013 08:04 AM
Has anyone installed the whiteline steering rack bushings? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-18-2013 05:40 PM
Will installing sub frame and tranny mount bushings cause premature wear? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-16-2013 03:56 PM
FS: Whiteline bushings. New, never installed stockysnail Brakes, Suspension, Chassis 0 02-05-2013 06:49 PM
