Old 10-27-2013, 02:54 PM   #1
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Using OBD2 Data to Calculate Tq/Hp
Is there a formula I can use to infer Torque or Horsepower from the OBD data? I know it's not completely accurate (but then again neither is a inertia dyno). I'd like to be able to calculate torque to asses changes to my engine.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-27-2013, 03:01 PM   #2
jamesm
here is a rough translation of the most basic version of the formula that innovate uses, which doesn't require an accelerometer. if you have an accelerometer you can get better results.
Code:
values in () are reasonable defaults (not necessarily correct for the 86)
Vehicle weight in kg = m (580)
Tire diameter in cm = td (53)
Gear ratio of run = gear_ratio (1.5)
Final drive ratio = finaldrive (4.375)
i Name of RPM channel = rpm (RPM)
Frontal area of vehicle (sqm) = Ar (2)
Drag coefficient = Cd (0.45)
Current atmospheric pressure (millibar) = atmp (1013.2)
Current temperature (degC) = temp (15)
#SAE correction factor
SAEcf = (1.18 * ((990/atmp) * sqrt((temp + 273.15)/298)) )- 0.18
#air density
density = 0.0412236 * atmp/ (temp + 273.15)
R = td / 200 #tire radius in m
a = slope(RPM) * pi * td/(6000 *gear_ratio * finaldrive)
#acceleration in m/sec^2
# speed in m/sec
v = (RPM * R * pi ) / ( gear_ratio * finaldrive * 30)
# aerodynamic draq in Newton
Fa = 0.5 * density * (v^2) * Ar * Cd
F = m * a + Fa
trq = F * R / (gear_ratio * finaldrive) # in nm
hp = trq * rpm / 7121
not saying it works or is perfect, just that is what innovate uses.
you can calculate all of this realtime or afterwards from logs using the ot-2, which uses the accelerometer in your iphone in addition to the mts obd2 stream.
Old 10-28-2013, 12:38 PM   #3
Gary in NJ
Gary in NJ's Avatar
Thanks for the input. I'm thinking that there should be a relationship between MAF (air consumed) and fuel flow. Since fuel has a known energy value and I know the AFR, there must be a a formula to connect this information. The only guess would be volumetric efficiency, but at WOT it must be only a 30% loss.
Old 10-28-2013, 12:44 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
The torqe app calculates it for you.
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
OBD2 Bluetooth Adapter Ravenlokk Engine, Exhaust, Transmission 49 09-04-2013 03:50 AM
OBD2.ca any good? zyvod CANADA 11 08-28-2013 10:34 AM
Ecutek Map Access, data logging Vs. obd2 sensor lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 01-06-2013 02:56 PM
obd2 engine sound app brichard0625 Engine, Exhaust, Transmission 4 09-25-2012 04:36 PM
