Drives: for the sake of driving
OEM coolant part #'s
Hey guys,
My coolant level is below the "low" mark on the overflow tank, so I figured I'll pick up a gallon and top it off. After doing some searching around the forum, I found a few conflicting part numbers, so I just wanted to know if anyone can confirm my assumptions or correct me if I'm wrong. It seems like both of these coolant types are the same, but the toyota stuff is ~$10 more. Here's the conclusion I came to: Toyota p/n: 00272-GTBC1 Subaru p/n: SOA868V9270 So, are these the correct coolant part numbers for our cars? Thank you!
'13 Argento FR-S
Anyone?
'13 Argento FR-S
Drives: 2013 Scion FR-S Raven
Distilled water
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
I'm afraid this won't cut it in the midwest winter, which is quickly approaching. I'd like to maintain the 50/50 mixture to be on the safe side.
'13 Argento FR-S
OOH KILL EM
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
00272-GTBC1 is the toyota version, so yes you're right
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
Great, thank you gentlemen!
'13 Argento FR-S
#8 | |
OOH KILL EM
You're welcome but before you make your purchase please take a look at this thread
http://www.ft86club.com/forums/showthread.php?t=26482 Quote:
Drives: WR Blue BRZ
so i'm guessing for the non 50/50 just coolant and antifreeze.
PN: SOA868V9210? |
#10 |
Just drive it
Drives: 13' FR-S
Isn't the bottle already 50/50 mixed? I just topped it off.
From Toyota, the description on back specifies "FR-S Engine Only" From Subaru, the super blue coolant. Either one is fine. |
#11 |
The Superblue is already a 50/50 so don't add water to it.
-mike |
#12 |
Drives: 2013 Scion FRS
Glad I found this thread, this is the one I'm about to purchase. Not trying to do what I do for my daily by going to Advance Auto for it.
https://www.amazon.com/Genuine-Subar.../dp/B007NLOZAU |
#13 |
PENTOFROST A3 at Autozone is the same stuff if not the supplier for the Subaru OEM coolant.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Coolant Disappearing | civicdrivr | Issues | Warranty | Recalls / TSB | 313 | 05-18-2016 09:56 PM |
| FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
| Adding Coolant | JLMtm | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-11-2013 07:03 AM |
| Coolant Levels | DriftEightSix | AUSTRALIA | 17 | 01-29-2013 09:19 AM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
