CANADA Canada
Old 10-21-2013, 02:16 PM   #1
rip curl
Drives: 13 BRZ
Rust proofing?
Where do you guys get your rust proofing done at?
I'm thinking of getting it done at MotorworX in Vaughan (Ontario). They use a product called DuraShield which doesn't drip as much as Krown (apparently, I've never had it done at MotorworX).
rip curl is offline   Reply With Quote
Old 10-21-2013, 03:43 PM   #2
project d
Drives: 2013 BRZ WRB
Got OEM toyota plus crown in markham
project d is offline   Reply With Quote
Old 10-21-2013, 06:37 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
Rust Check...drips more than Krown, but is very effective. I've been using it for 20 or so years.
Old 10-21-2013, 08:20 PM   #4
Kazuya
Kazuya's Avatar
Drives: Takumi
Where and price?
Kazuya is offline   Reply With Quote
Old 10-21-2013, 09:50 PM   #5
aSaki
Krown will drill holes on your door panel just a heads up but krown is good. It drips a bit but I own a garage so I left all the under covers off and let it dripped for 2 days before I put the covers back on
aSaki is offline   Reply With Quote
Old 10-21-2013, 10:59 PM   #6
roddy
roddy's Avatar
Originally Posted by Kazuya View Post
Where and price?
Lots of locations across the GTA. There's one at 2305 Markham rd...416-754-2128. The price is about $120.
Old 10-21-2013, 11:06 PM   #7
Kazuya
Kazuya's Avatar
Drives: Takumi
Thanks. I'm going to check it out, first time rustproofing ^_^
Old 10-28-2013, 04:12 PM   #8
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
So my dealer says my options through them are:
- Dripless oil spray (have to do every year) $110.10
- One time application (lifetime warranty) $695
Any advice? I want the best bang for my buck and don't mind re-doing it every winter, but also don't want to leave it vulnerable..
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 10-29-2013, 02:39 AM   #9
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Under Covers???
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 10-29-2013, 02:57 AM   #10
Kazuya
Kazuya's Avatar
Drives: Takumi
Booked an appointment with Krown between McCowan and Markham, the old guy doesn't sound friendly or knowledgeable.
Old 10-29-2013, 10:32 AM   #11
btune
btune's Avatar
If you going Krown, I recommend 2628 Saint Clair Avenue West. The owner there is a solid guy. I've been taking all my cars there for the past 4 years. They tend to get quite busy around this time. Usually cost around $100-$120.
AVOID the Krown at Lakeshore and Cawthra in Mississauga. I took my 370z there once. They took like 15min to do it, and it turned out they only sprayed the bottom.
btune is offline   Reply With Quote
Old 10-29-2013, 10:51 AM   #12
brianc
OCD
brianc's Avatar
Or just grab a can of T40 or Formula 3000 and just do it yourself
brianc is offline   Reply With Quote
Old 10-29-2013, 05:54 PM   #13
aSaki
Originally Posted by FLYFISHR View Post
Under Covers???
Those plastic panels under the vehicle that covers your engine, tranny, etc. Taking them off first will make their life easier and will probably spend more time going to every corner of your car. If you leave them own they will just shove their gun in without knowing where they are spraying and jusy blind spray and hope for the best. After the spray is done. Leave the covers off and let it drip on floor and not on your cover if you were to put them back right away after the spray
The Following User Says Thank You to aSaki For This Useful Post:
FLYFISHR (10-29-2013)
Old 06-19-2014, 11:44 PM   #14
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I got mines done at duratech rustproofing
They did a great job only thing concerns me is the holes they drill
Anyone know the chances of thoses holes rusting if I always clean my car and around theses holes as well
Thanks
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Rust-Proofing Gunk Taro CANADA 4 10-10-2013 08:57 PM
Subaru dealership rust proofing tinma Issues | Warranty | Recalls / TSB 49 09-20-2013 03:26 AM
BRZ limited has factory installed sound proofing ebgs500e BRZ First-Gen (2012+) — General Topics 36 05-27-2013 10:01 AM
Lug Nut Rust Wesley Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 04-14-2013 08:06 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
