Old 10-08-2013, 06:59 PM   #1
LazerBrZ
LazerBrZ's Avatar
Drives: Silver Limited BRZ
Need some Suspension advice!
Hey guys, in about a month I'll be moving to Norfolk and if any of you have driven there you know the roads are complete shit all around. I currently have Eibach Sportlines with stock shocks. And the ride is WAY rougher than I'd like. Anyone have any advice on how to smooth the ride out a bit? I want to keep the sportlines as I like the drop and cant afford to go full coilover setup right now, but I'm open to suggestions for sure.
I'm on a budget so thats a factor. I like the Koni Yellows but I'm not so sure about front inserts (nor do I have the equipment required to install them).
Let me know what you guys think, I'd appreciate it!
LazerBrZ is offline   Reply With Quote
Old 10-08-2013, 07:40 PM   #2
ModBargains.com
ModBargains.com's Avatar
Koni Yellows would be nice because they're adjustable, that way you can set the comfort level (rebound setting), to where it works for you. Anything adjustable so that you can get a good setting that works without having your head bob around all the time would work. The least expensive route would be shocks, or you can go all out and get a set of KW V3's which are rebound and compression adjustable, so that you can dial in the exact feeling you want to get out of the car.
Anything like BC, or HKS, coilovers are going to be too bouncy if you ask me, if the roads are as bad as you say they are, KW's are more tuned towards street driving, so have softer spring rates, and the valving on the shocks to match.
That's just my feeling on it though, I'm sure there are guys in your area that could give good recommendations too.
ModBargains.com is offline   Reply With Quote
Old 10-08-2013, 08:07 PM   #3
OrbitalEllipses
Drives: Attitude
Koni yellows on full soft or near full soft are very comfortable. I'd say they're an improvement over stock, even with my stiffer springs.
Old 10-08-2013, 08:55 PM   #4
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I offer Koni Yellow assembly We've built 3 sets of them, PM me if you decide to go that route.
Pure Automotive is offline   Reply With Quote
Old 10-08-2013, 09:47 PM   #5
Ross
Drives: 85 corolla gts
Koni Yellows with out a dought
Ross is offline   Reply With Quote
Old 10-08-2013, 10:21 PM   #6
Frostyman
Drives: 2013 Raven FRS
Norfolk? Def get the yellows. I'm gonna spring for a set before too long, hwy264 is a killer. Freakin speed bumps in the middle of the road and shit.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-09-2013, 08:36 AM   #7
infinite012
Drives: 13 DGM BRZ Ltd
I'm on RCE Yellow springs and stock shocks. It does fine on 264, 64, and 664.
By fine, I mean I'm still alive and my back doesn't get sore like it did in the STI (with BC BR coilovers) on the same roads.
infinite012 is offline   Reply With Quote
Suspension advice? GTBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 10:38 AM
Need Advice on 225 front and 245 rear tire suspension setting. Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-15-2013 06:32 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Some advice on suspension from serious drivers NON-VTEC Tracking / Autocross / HPDE / Drifting 15 02-01-2013 12:12 PM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 12:17 AM
