Old 04-08-2013, 10:02 AM   #1
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Unhappy Blown strut or other problem after spring install?
Hey guys,
So this weekend I decided to lower my FRS, I went about doing the install based on the instructions in the DIY section.
I remember reading about not spinning the shaft in the strut so I was extra careful not to do it in the front, the front appears to be fine.
However in the rear I couldn't get the nut off the shaft with hand tools and I didn't want to get killed by flying parts so I used an impact gun to remove the nut from the shaft. I put everything back together with hand tools making sure not to spin the shaft.
So everything back together I take the car for a spin and immediately notice a clunking/rattling sound coming from the back, really sounds like something is loose and rattling around after every bump. If you grab the rear fender and lift the car up and down you can clearly hear it from inside and outside the car.
I checked the strut mounts and the bolts where the strut connects to the LCA, everything seems to be tight and torqued properly.
So what's wrong then? Did I blow the rear struts using the impact gun (leading theory based on searches) or did I do something else that I'm not seeing or missing? What other symptoms would a blown strut exhibit?
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-08-2013, 11:15 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sadly, that is most likely. They usually leak, but I'm not sure if they will given the damage is usually more internal than just a seal I think with these failures. These OEM dampers seem way too sensitive to this IMO.
BTW next time I'd suggest removing the assembly whole, and then rent (free at many autoparts stores) spring compressors, and then use hand tools.. keeps you and the damper safe.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-08-2013, 12:32 PM   #3
f0rge
Sigh. Well the struts are reasonably priced at least (canadian dealer quoted $111/each).
This seems like a very poor design, do aftermarket (Koni) struts have the same problem?
Old 04-08-2013, 01:23 PM   #4
d1ck
Drives: Black 2013 FRS
As a general rule don't use an impact gun on any shocks. It tears up the shaft seals.
d1ck is offline   Reply With Quote
Old 04-08-2013, 05:39 PM   #5
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Sounds like hardware is loose.
Perhaps check all hardware that attaches to the rear lower control arm (inner & outer pivot bolts, sway bar end link, lower shock mount.)
Then check stuff up top like the rear shock tower bolts and then the shock shaft nut.
Nitro22 is offline   Reply With Quote
Old 04-08-2013, 08:55 PM   #6
Racecomp Engineering
The trick is this:
When reinstalling the top nut in the rear the best way to prevent the shaft from spinning is to put a LONG screw driver thru the bottom eyelet of the shock. Have a friend( STRONG FRIEND) hold each side of the screw driver with his feel. Then he should PULL UP on the rear shock MOUNT, while you use tools to secure the top nut. We install A LOT of these rears from Impreza's and BRZ's and use an impact gun....very sparingly with regards to impact speed, but the main thing here is when PULING UP on the mount this puts tension on the shaft and it prevents it from spinning freely and then the top nut DOES tighten ALL THE WAY DOWN.
What happened with you in this case( PROBABLY) is you tightened it but as it goes down the shaft it gets tighter and then there is so much resistance that it wont spin any longer on the threads so naturally most think that its bottomed out and its secure. WRONG. Its not and so it makes noise.
This can be done without an impact gun and requires more work but can be done.
Hope that helps you understand why. I say this after having 30-35 people bring their cars in with a rear noise and we show them what and why.
Myles
Old 04-08-2013, 09:37 PM   #7
mrk1
Drives: Sterling BRZ Ltd
Do the rears not have a space for an Allen key?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-08-2013, 09:39 PM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They do. Just remove the dampers assembled, it's easy.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-08-2013, 09:44 PM   #9
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
This really sound like the hardware is lose or the spring did not seat correctly.
MattF is offline   Reply With Quote
Old 04-09-2013, 09:28 AM   #10
f0rge
Are you saying it can be fixed? When I tightened the top nut I used an allen key and an open ended socket, but I only tightened it down to where it was from the factory, not until it was bottomed out.
Does it need to be bottomed out?
Old 04-09-2013, 10:01 AM   #11
xwd
Yeah it sounds like the top hat just isn't tightened down all the way.
If you damaged a strut internally to the point where it was clunking it would have pissed all the fluid out and your car would probably be bouncing around like crazy.
Old 04-09-2013, 10:43 AM   #12
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
+1 on something not installed properly or loose.
Over the past 10 years of installing suspension privately for myself or friends we have had strut shafts spin and have never had a failure because of it. Yes I know isn't good for the shock, but sometimes it happens.
You have to look at problems with the simplest solution first, you just loosened a bunch of stuff, chances are something is loose.
No Limit Motorsport is offline   Reply With Quote
Old 04-11-2013, 08:05 AM   #13
f0rge
Wow guys thanks for all the help, not tightening the top hat was exactly the problem. Unfortunately I had to take the struts out again to fix it, but everything is back together now and working as it should.
I owe you all a beer, you saved me from wasting $250.
Here's a terrible pic of the car in my underground. Eibach Sportlines.
Old 04-11-2013, 10:11 AM   #14
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
the key is to 'blip' the impact with tiny short blips to avoid actually spinning the shaft, and just loosen the bolt. if you stand there and hold the trigger down, you will spin your shaft.
Huehuecoyotl is offline   Reply With Quote
A simpler spring/strut install DIY -- no compressor needed jeebus DIY (Do-It-Yourself) Guides 120 01-17-2023 09:28 AM
Full Blown Turbo Kit Install This Weekend Gulf Breeze/Pcola/FWB King Tut Southeast 42 02-16-2013 03:24 PM
Eibach Sportlines on the BRZ - Blown Strut 01s0uljah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 02-14-2013 02:09 PM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
