Old 10-06-2013, 06:59 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
oil in the oil filter catch
Dip stick, says my oil is normal. I don't know why there is some in the catch. Oil filter seal leaking?
Old 10-07-2013, 04:11 AM   #2
ft_sjo
Drives: GT86
Perhaps an OE one wouldn't leak like that?
Old 10-07-2013, 09:01 AM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I'd say the oil filter gasket isn't sealing. I would change the filter ASAP and clean any residual oil before putting on the new filter.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-07-2013, 08:12 PM   #4
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
you are using the wrong oil filter. Subaru uses a special filter for the upside down design. Get an OE filter and your good to go.
youcantseeme24 is offline   Reply With Quote
The Following User Says Thank You to youcantseeme24 For This Useful Post:
Clipdat (10-08-2013)
Old 10-07-2013, 08:44 PM   #5
ML
ML's Avatar
This is my fourth of these filters, and this is the first to do this.
Old 10-07-2013, 09:31 PM   #6
youcantseeme24
hmmmmm well either get another or do the recommended thing and get a OE filter. Good luck
Old 10-07-2013, 09:33 PM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Performax filters have a 25% chance of leakage.
SloS14 is offline   Reply With Quote
The Following 7 Users Say Thank You to SloS14 For This Useful Post:
Carwhisperer (10-09-2013), Clipdat (10-08-2013), F1point4 (10-08-2013), lazyluka (10-08-2013), ML (10-08-2013), pmccut (10-08-2013), roddy (10-07-2013)
Old 10-07-2013, 10:23 PM   #8
Trac Toy
Trac Toy's Avatar
Quit being so cheap... Your probably running good oil, so buy a good filter. It's not a ten+ year old beater...
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 10-07-2013, 10:30 PM   #9
joop1987
Drives: 2013 FRS, Raven, Auto
The oil filter for Subaru EJ engines require OEM filters with a round rubber gasket or they leak. I wonder if the FA's have the same problem. Did you notice if the gasket was flat or round when you installed it?
joop1987 is offline   Reply With Quote
Old 10-07-2013, 10:32 PM   #10
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Round if I'm correct
Old 10-07-2013, 10:40 PM   #11
Tiremonkey0824
Drives: 2013 Argento 6mt
You should unscrew the filter and check the rubber gasket. I bet it has a tear somewhere.
Tiremonkey0824 is offline   Reply With Quote
Old 10-08-2013, 02:05 AM   #12
ML
ML's Avatar
quit being so bitch fantastic....anyway my brother owns/runs a shop and this is the filter he recommended.
Old 10-08-2013, 06:07 AM   #13
ft_sjo
Drives: GT86
He recommends a filter which leaks. He must not like you.
The Following User Says Thank You to ft_sjo For This Useful Post:
youcantseeme24 (10-09-2013)
Old 10-08-2013, 06:30 AM   #14
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
It is round-ish.
FrX is offline   Reply With Quote
Bad Catch Can? grostoine Issues | Warranty | Recalls / TSB 7 09-19-2013 08:05 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
Oil Catch Can.? Cjs_ Engine, Exhaust, Transmission 18 03-01-2013 12:58 AM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 11:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
