Drives: 13 White MT FR-S
oil in the oil filter catch
Dip stick, says my oil is normal. I don't know why there is some in the catch. Oil filter seal leaking?
#2 |
Drives: GT86
Perhaps an OE one wouldn't leak like that?
#3 |
Seems Legit
Drives: Toyota
I'd say the oil filter gasket isn't sealing. I would change the filter ASAP and clean any residual oil before putting on the new filter.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#4 |
Drives: 2013 subaru brz
you are using the wrong oil filter. Subaru uses a special filter for the upside down design. Get an OE filter and your good to go.
| The Following User Says Thank You to youcantseeme24 For This Useful Post: | Clipdat (10-08-2013) |
#5 |
This is my fourth of these filters, and this is the first to do this.
#6 |
hmmmmm well either get another or do the recommended thing and get a OE filter. Good luck
#7 |
Drives: 2013 FR-S whiteout
#8 |
Quit being so cheap... Your probably running good oil, so buy a good filter. It's not a ten+ year old beater...
.o0+Eric+0o.
2016 Chrysler 200S 3.6 2013 FRS 6MT |
#9 |
Drives: 2013 FRS, Raven, Auto
The oil filter for Subaru EJ engines require OEM filters with a round rubber gasket or they leak. I wonder if the FA's have the same problem. Did you notice if the gasket was flat or round when you installed it?
#10 |
Boosted
Drives: Not a supra....yet
#12 |
quit being so bitch fantastic....anyway my brother owns/runs a shop and this is the filter he recommended.
#13 |
Drives: GT86
He recommends a filter which leaks. He must not like you.
| The Following User Says Thank You to ft_sjo For This Useful Post: | youcantseeme24 (10-09-2013) |
#14 | |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
| Bad Catch Can? | grostoine | Issues | Warranty | Recalls / TSB | 7 | 09-19-2013 08:05 PM |
| Oil Catch Can? | eblamble3 | Engine, Exhaust, Transmission | 4 | 03-15-2013 11:58 AM |
| Oil Catch Can.? | Cjs_ | Engine, Exhaust, Transmission | 18 | 03-01-2013 12:58 AM |
| Does anybody know exactly what filter the injen Sri uses? I want to get a new filter | Frsexxxy | Engine, Exhaust, Transmission | 13 | 02-19-2013 11:04 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 03:40 PM |
