Old 10-03-2013, 12:14 PM   #1
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
What Bore do we need on wheels?
Couldn't find an answer here for the stock Bore.
I'm looking at these spacers:
http://www.evasivemotorsports.com/mm5/merchant.mvc?
I noticed
H&R DRM Wheel Spacers - 25mm / 12x1.25mm / 5x100 / Bore: 56mm
H&R DRM Wheel Spacers - 25mm / 12x1.5mm / 5x100 / Bore: 54.1mm
H&R DRM Wheel Spacers - 25mm / 12x1.5mm / 5x100 / Bore: 57.1mm
I know the 5x100 is the stock bolt patter but what about that "Bore" specification at the end?
I'm assuming thats the bore of the bolt holes. Anyone know which is the right stock fit?
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 10-03-2013, 12:19 PM   #2
b2autodesigns
b2autodesigns's Avatar
Drives: 1991 Galant VR4
You need this one.
H&R DRM Wheel Spacers - 25mm / 12x1.25mm / 5x100 / Bore: 56mm.
Check out my spacers. Just like the H&R spacers.
http://www.b2autodesigns.com/index.php?cPath=1129_1216
b2autodesigns is offline   Reply With Quote
Old 10-03-2013, 12:34 PM   #3
SillySaxon
SillySaxon's Avatar
Excellent packages, though I want 30mm for the back unfortunately.
If you had a pair of 20mm for front and 30mm for the back i'd buy them at your prices no problem.
Old 10-03-2013, 01:14 PM   #4
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The hub as a 56.1 mm OD
kask2_6.0 is offline   Reply With Quote
Bore of FR-S rims versus TC1? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-05-2015 11:28 AM
Center Bore MooKz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 03-09-2015 03:56 PM
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 08:00 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
