Old 10-27-2012, 09:45 PM   #1
stocktc1
Drives: scion tc
Bore of FR-S rims versus TC1?
Putting FR-S stock rims on TC1 (trying to save money).
Are these the correct bore?
tC1 Wheel
17x7 +45mm Bore 54.1
Source ebay
FR-S Wheel
17x7 +48mm Bore 56.1
Do they even make hubcentric rings for 56.1 to 54.1 other than http://www.hubcentric-rings.com?
stocktc1 is offline   Reply With Quote
Old 10-27-2012, 10:30 PM   #2
Tiremonkey0824
Drives: 2013 Argento 6mt
Frs wheels are 5x100. Tc bolt pattern is 5x114. You will need an adapter if you want to fit these.
Tiremonkey0824 is offline   Reply With Quote
Old 10-27-2012, 10:49 PM   #3
stocktc1
Drives: scion tc
Actually i think the 1st generation TC is the same as the FR-s but the 2nd generation TC is not 5x100?
Old 10-27-2012, 11:21 PM   #4
hippari
I Love your GUCCI Wheels!
hippari's Avatar
Drives: Raven Black FR-S
Send a message via AIM to hippari
i unno about the 2nd gen, but the first gen is 5x100. do you really need hubcentric rings though? people run random aftermarket wheels all the time without em.
Just make sure you have proper nuts for the fr-s wheels if you put them on the tc.
@jinxyboi | @_iLLdynasty
Rice for the Rice God
hippari is offline   Reply With Quote
Old 10-28-2012, 12:05 AM   #5
stocktc1
Drives: scion tc
Arent the bolts not supposed to carry the entire weight of the vehicle and you need hubcentric rings to help prevent that?
Old 10-28-2012, 12:07 AM   #6
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
tC1 Wheel
Source ebay
FR-S Wheel
You would have to bore the wheel bigger?
Spartan65 is offline   Reply With Quote
Old 10-28-2012, 02:47 AM   #7
hippari
hippari's Avatar
I suppose that's true since they do make hubcentric rings for a reason, but when you consider how often some people are running gigantic, heavy, low offset wheels with significantly larger hub bores on a daily basis without frequent wheel hub bearing failures or lug bolts sheering off I wouldn't sweat it too much.
Though, I guess my advice is mostly speculative, so I don't want to put you in a position where something could break on your car.
http://www.motorsport-tech.com/hub_rings.html
they can make specific sized hubcentric rings (and spacers/adapters) to order. Knew a guy who made hubcentric spacers that were 50mm thick lol
Old 10-28-2012, 03:41 AM   #8
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
The hub rings won't carry any of the car weight. Seems they are mostly used when mounting the wheels to ensure they are centered while tightening the nuts...which is why they can get away with making them in plastic.
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
The Following User Says Thank You to sho220 For This Useful Post:
hippari (10-28-2012)
Old 10-28-2012, 12:58 PM   #9
hippari
hippari's Avatar
there we go, good to know
Old 10-28-2012, 12:58 PM   #10
stocktc1
Drives: scion tc
Only custom made for $100 for 4 rings.
Do you think it wont matter much because the ring will be so small? 56.1 to 54.1 Hubcentric Rings?
Old 10-28-2012, 08:04 PM   #11
sho220
sho220's Avatar
Ouch 25 bucks a pop? Most wheel places through hub rings in for free. Unless you have a really oddball fitment, that's highway robbery...
Old 10-29-2012, 02:45 PM   #12
stocktc1
Drives: scion tc
Do you guys think I need rings? Dont want my wheels falling off.
Old 10-30-2012, 03:01 PM   #13
stocktc1
Drives: scion tc
Anyone think I need rings for 56.1 to 54.1 difference? thank you
Old 10-30-2012, 03:11 PM   #14
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
It won't fit. No rings will change that.
Don't you understand that the FRS has a center bore of 56.1 and the tC is 54.1. Do you not understand the 2mm overlap? The tC wheels won't fit the center bore.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 08:00 PM
My FRS baseline VERSUS Visconti e85/Perrin/Injen/Motiv setup TyperRspec789 Engine, Exhaust, Transmission 15 12-24-2012 08:10 PM
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-08-2012 06:25 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Size Comparison: FR-S versus tC and GT-R CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 58 03-05-2012 10:28 PM
