Old 09-19-2013, 10:34 PM   #1
ndsleep612
Drives: Thee Argento Cricket
Tow hook bumper hole vs. elements
My FRS is my daily driver and I was wonder if the exposed hole for the tow hook bolt for the front plate relocation frame would be bad for the elements (ie. rain)?
Does the foam behind the bumper mold or any metal parts gets rusted behind the bumper? Thanks
ndsleep612 is offline   Reply With Quote
Old 09-19-2013, 11:14 PM   #2
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
in sf you should be fine. we don't get much corrosion out here. if you are worried about the front thread getting build up in the hole you can thread in the correct metric bolt in the mean time or rub in some Vaseline. the foam is inorganic so it shouldn't mold.
garfull is offline   Reply With Quote
Old 09-20-2013, 09:24 PM   #3
VirUzxZ
Drives: Black on Black on Black
from what ur asking i'm assuming u have a plate re-locator and are asking about the abnormally large hole that is left once u pull off the cover piece?
I just tapp'd and drilled a hole corresponding to the size of the bolt(just a bit bigger) of the re-locator. Glued soft rubber washer that i had lying around on the inside of the piece and pop'd it back in. pushed in the Bolt that came with the re-locator and done. Looks clean and satisfied my OCD.
VirUzxZ is offline   Reply With Quote
Old 09-20-2013, 10:10 PM   #4
JDMenrique
DEEEERP
JDMenrique's Avatar
Buy corban and coat the threads, stuff is great.
JDMenrique is offline   Reply With Quote
Drilling a Hole for Tow Hook or License Plate Hanakuso DIY (Do-It-Yourself) Guides 28 04-12-2019 05:02 PM
Bottom mount setups and the elements... Skyllz Forced Induction 14 06-10-2013 10:09 PM
BRZ tow hook cover hole mod for license plate holder TSY BRZ First-Gen (2012+) — General Topics 19 05-10-2013 02:58 AM
