Old 06-09-2013, 03:32 PM   #1
Skyllz
Drives: Something fun.
Bottom mount setups and the elements...
I've been wondering, how are/will the bottom mounts setup fare with snow, salt, crap and such we have in the winter?
Is it a case of "dont run it in the winter" or it's not that bad?
I have seen the JDM underbody plastics and such, not sure it would be a good idea with a red hot turbo under there.
Just wondering...
Cheers
Skyllz is offline   Reply With Quote
Old 06-09-2013, 04:36 PM   #2
wparsons
wparsons's Avatar
Have you looked at a stock one from underneath? They have a metal pan under the whole engine bay. The plastic parts don't start until behind the engine bay.
flickr
Old 06-09-2013, 06:54 PM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
The Jdm under panels install over a solid surface more or less. There is nowhere under those panels to install anything. Most undermount kits install over the factory metal plate.
industrial is offline   Reply With Quote
Old 06-09-2013, 07:58 PM   #4
Skyllz
Ah, Makes sense, I had been trying to find pictures of setups with the metal plate back in place and did not find any.
Old 06-09-2013, 08:08 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Couldn't link the picture but google p tuning Frs turbo kit and you'd find a few pictures
Old 06-10-2013, 05:10 AM   #6
jamesm
I couldn't own a bottom mount setup in florida. Too much standing water from the summer downpours. It's not uncommon at all to find yourself up past your door sills in water all of a sudden. I can't imagine the havoc that could cause, whether from ingestion or just dunking a 1500deg piece of very precisely manufactured metal in.
There's a good reason you don't see many (any?) factory turbos mounted that low.
Old 06-10-2013, 05:10 AM   #7
jamesm
I couldn't own a bottom mount setup in florida. Too much standing water from the summer downpours. It's not uncommon at all to find yourself up past your door sills in water all of a sudden. I can't imagine the havoc that could cause, whether from ingestion or just dunking a 1500deg piece of very precisely manufactured metal in cold water.
Old 06-10-2013, 10:46 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I wouldn't worry about a bottom mount. There is a splash shield, and the filter is mounted way up in the engine compartment, so you will be fine even if you drive through a lake which is I guess what Central and South Florida people do. Because Subaru rally car?
Old 06-10-2013, 01:16 PM   #9
ptuning
ptuning's Avatar
Drives: White FR-S
This ^^^^^
If you run into water deep enough to somehow damage the turbo, you'll crack the hot engine block in the process so it'll be the least of your worries. Porsche has been running a low mount single or twin oil scavenged turbo system in their 911 series for the past 4 decades without any worries of damaging the turbo. :happy0180:
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
hmong337 (01-14-2014)
Old 06-10-2013, 04:48 PM   #10
jamesm
Originally Posted by ptuning View Post
This ^^^^^
Good call. I trust you've done your research . I'd still be wary of ingestion, but I'm just paranoid like that.
Old 06-10-2013, 04:57 PM   #11
ptuning
ptuning's Avatar
Drives: White FR-S
Gotcha, if you're talking about water ingestion through the intake, that would be impossible with our setup since the filter sits up high in the engine compartment.
Old 06-10-2013, 09:21 PM   #12
charged86
charged86's Avatar
Bottom mount systems and a miss judged speed bump... They are all element proff. Rule of thumb if its air tight its also water tight
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-10-2013, 09:48 PM   #13
OrbitalEllipses
Drives: Attitude
Honestly I wouldn't even worry about. OEMs even have bottom mount setups and I wouldn't concerned so much about water ingestion as much as thermal shock. The OEM setups have shown that thermal shock isn't an issue...just don't drive it into a river.
Old 06-10-2013, 09:51 PM   #14
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Not sure about PTuning (but curious) but the first bottom mount from accelerated performance was mounted higher than the frame.
If you're hitting the speedbump with the turbo WTF have you done to the body?
Chewie4299 is offline   Reply With Quote
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Setups for drifting? 6-Shift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-11-2013 10:08 PM
Anyone here in SQ setups? Dave-ROR Electronics | Audio | NAV | Infotainment 25 04-03-2012 07:13 AM
