Old 10-14-2012, 03:23 PM   #1
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
BRZ tow hook cover hole mod for license plate holder
I know there's a DIY for the FR-S here:
http://www.ft86club.com/forums/showthread.php?t=15922
I figured I'd just post some pics for our BRZs since they are different. Pretty simple to do- about 20 min, just be patient.
Instead of using a drill I used a Dremel since the hole had to be oval because of the angle of the cover.
This is what it looks like without the cover which I didn't really like and you could see it open from the side:
First I made a template of the cover, laid it over the grimmspeed tow hook shaft, and put a hole in the template at the center of the shaft. Looking back, cutting out a hole here may have been a better idea than what I did:
Then I put the template over the cover and drilled a hole at the location of the tow hook shaft. After drilling the hole and measuring the size of the shaft from center, I used a dremel to cut out a larger hole. Once I made a round hole I test fitted it over the tow hook and used the dremel to make the hole oval on the horizontal plane to adjust for the angle the tow hook plate is over the tow hook until it fit nicely. Hopefully you can see the slightly 'ovalized' hole here:
After replacing the tow hook cover you can see it looks better even if you can't really notice it behind the license plate.
It would be nice if GrimmSpeed and/or Perrin had a template outline included in the directions. I'm sure it would have made this even easier.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 10-14-2012, 08:19 PM   #2
ESC POD
ESC POD's Avatar
Drives: Sterling Silver BRZ
Template was exactly what I was thinking when looking to buy one of the relocation kits...it would be a great idea.
Activating: ESC POD...let's Drive!!
ESC POD is offline   Reply With Quote
Old 10-14-2012, 09:31 PM   #3
TSY
TSY's Avatar
It would be nice to have one and I half expected one to be with the instructions. But it's pretty easy to make your own template- you just have to have the tracing skills of a 1st grader.
Old 10-14-2012, 10:42 PM   #4
ggpaul
socalsouthbay_86
ggpaul's Avatar
Drives: Scion FR-S 2013
I did this to my car as well. What's your opinion on those electric retractable license plate brackets where it comes from the bottom?
ggpaul is offline   Reply With Quote
Old 10-14-2012, 11:25 PM   #5
TSY
TSY's Avatar
I thought about one of the retractable plate holders. I figured it's more complicated than it's worth. The Tow Hook license plate holder is a much simpler solution.
Also, for track days you can easily remove the front plate if you want.
Old 10-14-2012, 11:28 PM   #6
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
If it makes you feel better mine is a huge ass rectangle. But on the plus side I no longer need a flathead to remove the cover on my FR-S.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 10-15-2012, 11:22 AM   #7
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I've also thought of doing this but have not gotten the balls to try it on my cover. Anybody know what the part number is for this cover? Also, I was trying to figure out a good way to keep moisture, etc out of the hole. Was thinking an oring or gromet but have not gotten much luck because of the odd oval shape.
Old 10-15-2012, 11:31 AM   #8
ESC POD
ESC POD's Avatar
You might have luck with a large rubber grommet/plug? I can picture one that seats around the edge of the hole one would cut then trimming a hole just a bit smaller than the bracket bolt that protrudes from the bumper...then sliding the grommet hole over for a nice tight seal?
Old 10-15-2012, 11:36 AM   #9
RYU
RYU's Avatar
Drives: really slow...
Can you post some full car pics of the plate on the car. Multiple angles would help
Can you tilt this side to side, meaning point it facing the curb more vs. straight towards the front?
You might have just pushed me over the edge and order one!
RYU is offline   Reply With Quote
Old 10-15-2012, 10:55 PM   #10
TSY
TSY's Avatar
^^^^I'd have to pull my car out and take some pics and it's pouring outside and dark, so instead here are some other threads with pics so you can see:
http://www.ft86club.com/forums/showt...ate+relocation
The plate is quite adjustable as to how you position it and you can angle it. I'm quite happy with it as well as not having holes drilled into my bumper.
Old 10-15-2012, 10:58 PM   #11
TSY
TSY's Avatar
It's not too hard to do and I doubt the cover costs more than $20. You don't even have to paint it.
I thought about a grommet but I didn't think it would do much.
Old 10-16-2012, 12:02 AM   #12
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Cover only costs you $5 - $6 from Subaru for the BRZ.
It's about $30 (more or less) from Scion for the FR-S because of the paint match.
I bought an extra; kept it in its original packaging, and left it in my trunk where the spare tire and jack is.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 10-16-2012, 11:03 AM   #13
cinnabar
I used tubular foam pipe insulation to surround the mounting post:
http://tinyurl.com/8nqy2af
It cuts easily with scissors or a knife and fills up most of the empty space in the cavity.
cinnabar is offline   Reply With Quote
Old 05-09-2013, 06:56 PM   #14
Pandle
Drives: CBS BRZ
Where did you buy the covers from?
All kinds of gains....
Pandle is offline   Reply With Quote
Drilling a Hole for Tow Hook or License Plate Hanakuso DIY (Do-It-Yourself) Guides 28 04-12-2019 05:02 PM
CrossoverAuto.com - FRS/BRZ/86 Perrin Front Plate Tow Hook Holder *NO DRILL!* Crossover Auto Exterior Parts - The Rest 8 05-18-2014 07:03 PM
Now available!!! PTUNING Adjustable Front License Plate Holder w/ Tow Hook Mount Mrc@ptuning Exterior Parts - The Rest 24 03-14-2013 11:50 AM
Now available! PTUNING Adjustable Front License Plate Holder w/Tow Hook/ camera mount Mrc@ptuning Exterior Parts - The Rest 29 12-07-2012 02:37 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
