Old 09-17-2013, 08:47 AM   #1
Latiii
Latiii's Avatar
Drives: Currently I have a tC
rattling when braking
Hey I recently got my FRS like two months ago. As I was driving two weeks later my FRS when braking gives a rattling sound from the engine. The only way it does not rattle is if I brake while pressing the clutch. I took it to Toyota twice and they can't seem to find anything wrong or out of place. Has anyone experienced the same problem and found a solution? Please help.
Latiii is offline   Reply With Quote
Old 09-17-2013, 09:34 AM   #2
nalc
Drives: 13 BRZ Limited 6MT GBS
I've found that my car makes a short rattle occasionally when I'm braking at low speeds (under 30mph, although I'm not sure if it's simply that it's not loud enough to hear at higher speeds) with the car in neutral and my foot off the clutch. It seems to always happen with my hand near or touching the shifter, but I'm not sure if that's just because I usually have my hand there when I'm in that situation, or if my hand is causing it.
I find the car makes a quick jackhammer noise (not super loud, but noticeable) for about 4 times, then is quiet.
No idea what it is, does this sound like what you notice?
nalc is offline   Reply With Quote
Old 09-17-2013, 10:17 AM   #3
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
I get the same rattle but I believe its the direct injectors functioning normally. Although I'm not completely sure so anyone feel free to chime in...
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 09-17-2013, 10:52 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Is this your first manual transmission car by chance?
Old 09-17-2013, 04:36 PM   #5
Latiii
Latiii's Avatar
no i have owned 4 manual cars and can drive manual very good but it happens when i am in neutral and braking. it happens when i am in gear and braking . RPM's are above stall limit so i doubt its because i am close to stalling.
Old 09-17-2013, 04:38 PM   #6
Latiii
Latiii's Avatar
YES! exactly. the reason i ask is because i had another manual FRS and it did not make those noises. I also have a friend who has one and when i drive his, it doesn't make that sound.
Old 09-17-2013, 05:06 PM   #7
Dezoris
Dezoris's Avatar
The best thing to do with the situations is either dealer it or find another owner locally to compare.
Old 09-18-2013, 09:23 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That was going to be my guess. Does it do it at all speeds?
Old 09-18-2013, 10:42 AM   #9
automatic
Drives: WRB BRZ
Mine does it too...but I cant seem to find the conditions to reproduce it so I havent bothered taking it into the dealer.
It happens when I'm slowing to a stop...so brake and then almost immediately clutching in.
automatic is offline   Reply With Quote
Old 09-18-2013, 06:33 PM   #10
Latiii
Latiii's Avatar
Dealer looked at it and heard the sound. They just cant seem to find it.
Old 09-18-2013, 06:34 PM   #11
Latiii
Latiii's Avatar
It sounds when i am slowing down under 30 for a complete stop or just slowing under 30.
Old 09-19-2013, 09:44 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My guess would be throwout bearing noise if the clutch changes the sound. It is probably RPM dependent and only does it at lower RPM levels. Do the same stop from 30 to 0 in 1st, 2nd, 3rd, and 4th gear and note any differences.
Old 09-27-2013, 10:09 PM   #13
brzerk1
brzerk1's Avatar
Drives: SWP BRZ LIMITED
My brz started doing it and has about 1400 miles on it. I've noticed that it seems to do it only with the AC on in nuetral, clutch doesn't seem to effect it.
brzerk1 is offline   Reply With Quote
Old 09-27-2013, 10:55 PM   #14
humfrz
It's my understanding that the clutch and the brakes share the same fluid reservoir. Since your rattling sound may be related to movement of the clutch, maybe the ABS system is making the noise and the clutch movement is interrupting it.
Is the clutch/brake fluid reservoir up to the full mark?
Maybe their is air in one or both systems?
If so, bleeding the systems may settle it down ....
humfrz
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 08:54 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
Transmission rattling Sonolin Scion FR-S / Toyota 86 GT86 General Forum 6 04-29-2013 01:57 PM
Rattling From The Clutch Wesley Issues | Warranty | Recalls / TSB 5 01-31-2013 09:27 AM
BRZ Rattling w/ video lavisxice Issues | Warranty | Recalls / TSB 11 11-06-2012 10:07 AM
