Old 04-28-2013, 03:28 PM   #1
Sonolin
Transmission rattling
I've been loving my new asphalt m/t, but notice when I'm a little low in RPMs usually in 2nd & 3rd the transmission rattles quite a bit. And I'm not talking bogging speeds, I mean like 1k-2k rpm (so just before the engine bogs I guess). Its a little annoying and it mostly annoys me when my hand is resting on the shift knob, I can feel the whole shifter rattling around.
Again this only really happens in 2nd & 3rd gear it seems, and only around 1k-2k rpms. Its not a whole lot of rattline but it does rattle a bit and I find it a little annoying (and it worries me about rattles in the future if this is only happening ~1k miles)....
Should I get it serviced? Anybody else have this happen? Is this normal in m/t cars (this is my first manual)?
I also notice the car really doesn't like 1st gear low in revs either (usually in stop & go) when I'm not on the gas. If I take off the gas the engine rpms drop extremely fast and the engine starts bogging ~1-1.5k (not the usual <1k).
Am I just letting the revs drop too much? I try not to use my clutch unless I have to. I might just be a noob with the manual...
Sonolin is offline   Reply With Quote
Old 04-28-2013, 03:51 PM   #2
Supermassive
Supermassive's Avatar
Yes 1-2k in anything that isnt idling is too low to be driving at. You make almost no power that low in the rpm band so the engine struggles to keep the car moving at the speed you are at. This causes juddering from the transmission. 2.5k-3k is a good around town cruising rpm range but you'll have to down shift to pass anything.
I'm assuming this is a first manual transmission car for you. Lower RPM doesn't necessarily mean better mpg the car is actually made to cruise at 3-4k rpm cruising at lower rpms isn't beneficial in the least and allowing your engine to bog down can cause premature wear.
Supermassive is offline   Reply With Quote
Old 04-28-2013, 04:21 PM   #3
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
^ what he said.
It usually means you're in too high of a gear for the rpm range/speed you're going.
Enraged21 is offline   Reply With Quote
Old 04-29-2013, 01:26 PM   #4
frslee
Just drive it
Drives: 13' FR-S
downshift!!
frslee is offline   Reply With Quote
Old 04-29-2013, 01:30 PM   #5
Mikem53
Drives: FR-S 6MT
Normal sounds for low rpm after clutch release.. Like ball bearings in a tin cup..
I love hearing all the mechanicals from the gear box... And the tranny is right there under the stick.. No fwd bs linkage that looses the sounds and feel of the tranny.. I'm loving all the sounds and feel you get from just simply driving...
Mikem53 is offline   Reply With Quote
Old 04-29-2013, 01:36 PM   #6
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
This is normal. I used to worry about this noise too. I even made a thread too. I try to keep the RPM 2000+ now.
Sigh-on-Rice is offline   Reply With Quote
Old 04-29-2013, 01:57 PM   #7
Sonolin
Thanks guys! I'll just make sure to cruise at 2k+ from now on.
Normally I'm "cruising" at ~6-7k so this is rarely a problem
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 08:54 PM
Rattling From The Clutch Wesley Issues | Warranty | Recalls / TSB 5 01-31-2013 09:27 AM
BRZ Rattling w/ video lavisxice Issues | Warranty | Recalls / TSB 11 11-06-2012 10:07 AM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
