Old 11-03-2012, 09:34 PM   #1
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
BRZ Rattling w/ video
[ame="http://www.youtube.com/watch?v=UIs9temw8Kc"]2012 11 01 17 36 32 - YouTube[/ame]
fixes? anyone else have this problem, heard it the loudest in the beginning
lavisxice is offline   Reply With Quote
Old 11-03-2012, 09:39 PM   #2
rhysmcinerney
Drives: GT86 Auto
i heard it briefly but a better video is needed.
rhysmcinerney is offline   Reply With Quote
Old 11-03-2012, 10:41 PM   #3
Burrcold
Drives: Subaru BRZ Limited
I couldn't hear anything and that video was terrible.
Old 11-04-2012, 05:38 PM   #4
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
ill try to get a better one next time
Old 11-04-2012, 05:54 PM   #5
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
My FR-S rattles on acceleration from time to time, where does it sound like it is coming from?
briang0901 is offline   Reply With Quote
Old 11-04-2012, 06:40 PM   #6
Yruyur
Yruyur's Avatar
Need better video and where you think it's coming from. There are a tin of threads in fixes and complaints for the shield underneath that needs washers(mine always rattled at 4200rpm under load), shifter rattle, door panel rattle with music, under the dash area and the sound tube being mounted with a soft rubber that allows the resonator to hit the top of the engine.
Sent from my flux capacitor using Taptalk
Old 11-05-2012, 05:47 AM   #7
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
the rattle usually occurs at low rpm when i add little throttle, and the sound always comes from under the car.
Old 11-05-2012, 08:33 AM   #8
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Your talking about this one right. I have it to thought it was normal
Found a thread on it
http://www.ft86club.com/forums/showthread.php?t=8112
ArKiTeCkT is offline   Reply With Quote
Old 11-05-2012, 10:40 PM   #9
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
yeah but i think it only happens to me when im moving x_x
Old 11-05-2012, 11:20 PM   #10
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
The problem is that you are shifting too early, the engine was designed to shift up at a higher rpm(3k), from the video you were already changing gears when you just got to 2k rpm.
You should be downshifting if your RPM is around 1,500 and try to keep it above 1,800 if you want to gradually accelerate.
You can cruise at 1,500 rpm but you must downshift if you want to accelerate. If you are at 1,500 rpm and start to accelerate, you are damaging your powertrain from those vibrations!
As far as vibration when starting from idle, same thing. You let go of the clutch too early AND your rpm is not high enough. I dont know the starting point from idle because I never look at my gauge but you should be starting around 1,500 rpm and keep the clutch in until you feel the gear butters up(8mph +/-).
It sounds a bit more complicated than it really is, but all it takes is for a couple weeks of practice and getting use to it. Goodluck
LeeMaster is offline   Reply With Quote
Old 11-06-2012, 02:36 AM   #11
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
is this really the case o_o all my previous cars ive shifted at 2k rpm =/ hmmmmm ill start shifting and driving at higher rpms then x_x sorry if i damaged my baby </3
Old 11-06-2012, 10:07 AM   #12
LeeMaster
Red wine
Yeah I also currently drive an older 1997 Impreza 5spd and I know exactly what you mean.
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 08:54 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 07:48 AM
Center Console Rattling Fixed!! Ericfrs Scion FR-S / Toyota 86 GT86 General Forum 8 08-07-2012 10:01 PM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-26-2012 11:19 PM
New Spy video Matador BRZ Photos, Videos, Wallpapers, Gallery Forum 7 01-05-2010 11:47 PM
