Old 09-13-2013, 05:18 PM   #1
KSpider
KSpider's Avatar
Drives: '14 S4
Hardwiring V1 - BRZ ... Ground wire?
Can I just connect the V1 provided ground wire to the screw on the back of the dome light? This is the only screw I can find... will this ground it?
Other suggestion?
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 09-13-2013, 05:49 PM   #2
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I tapped mine into the homelink mirror wiring harness. If you don't have a homelink mirror the harness plug will be tucked away in the headliner next to the dome light.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 09-13-2013, 06:11 PM   #3
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Other suggestion?
There is another thread that I posted pictures in. You should be able to get an idea of which wire to tap in to.
Ranatsu is offline   Reply With Quote
Old 09-14-2013, 01:36 AM   #4
KSpider
KSpider's Avatar
Drives: '14 S4
I finished the hardwiring... What happens if the ground wire does not have a good connection?
Old 09-15-2013, 07:21 PM   #5
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
It simply wont work, or work intermittently. I would suggest just tapping into any other ground wire.
I used a Escort passport 8500, with smart cord for remote muting, and powered it off of the cigarette lighter in the center console. I just tapped into both the power and ground for those.
Otherwise, any metal bolt that bolts into metal will work fine. But don't worry about something tragic happening if for some reason you ground it wrong. It just won't turn on.
86-tundra is offline   Reply With Quote
Old 09-15-2013, 09:36 PM   #6
KSpider
KSpider's Avatar
Drives: '14 S4
Thanks, in fact, the ground came loose yesterday and it didn't turn on... I just wanted to make sure it wasn't going to explode.
DIY: Hardwiring your radar detector speedracer38 DIY (Do-It-Yourself) Guides 108 09-08-2019 10:06 PM
Wire Tuck DIM Cosmetic Modification (Interior/Exterior/Lighting) 20 08-11-2013 04:54 PM
best way to install 12v wire for amp?? derka-derka DIY (Do-It-Yourself) Guides 5 03-17-2013 12:57 PM
How did you wire your new speakers? crazyfrenchbiker Electronics | Audio | NAV | Infotainment 16 01-17-2013 12:18 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
