Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 07-16-2013, 12:36 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
"click" sound only when throttle is engaged, and dis-engaged AT
After an Auto-X event, I noticed a "click" sound only when I take off in first (M mode) and when I take my foot off the pedal, another "click" sound. It seems like it is coming from the rear diff area, not from engine bay. Anyone here have similar issues? When I am free revving my engine in neutral, no click sound what so ever, so seems like it needs to be engaged in gear. Only on take off's, and a very slow take off, I don't hear the "click" sound.
Throttle on - "click" and it stops, even after I shift up, only at take off it makes the noise.
Throttle of - "click", once more, then no noise, even after going to a stop.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-16-2013, 12:40 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Drives: 2015 FR-S AT, 2019 CX-5
Smile
Throttle body maybe?
OFT Stage 2 UEL E85/Nameless Performance 3 inch axleback with 5 inch mufflers/ TRD CAI / CNT UEL/ Cusco Strut BAR & LHD Brake Stop / "JDM" Toyota Badges / WinJet JDM headlights - DRL MOD from fteightysix.com - 5000K Diode Dynamics HID kit / Diode Dynamics LED interior Lights and sidemarker bulbs / JDM Clear Sidemarkers / Diode Dynamics LED switchbacks/ OLM LED rear turn signals / Tap Turn Relay
Old 07-16-2013, 03:28 PM   #3
BRZPDX
Boosted Member
BRZPDX's Avatar
I though about this too, but if it is the throttle body, it will "click" if I free rev the engine, but only when the car is in motion, which leads me to think it is coming from the tranny or the rear diff. I don't feel any difference other than the odd noise.
Only recent changes were changing my ATF to RedLine high temp fluid, and my diff oil was changed out like 2 months ago to Motul high temp fluid. And ofcourse a hard day at Auto-X.
Old 07-16-2013, 05:39 PM   #4
FRSBRZGT86FAN
Smile
I think it would be best to take it to the dealer under warranty they won't deny you for Auto-X as long as you don't have any aftermarket mods that affect the drive-line (fluids won't void it). Best of luck, I think you should head to the dealer.
Old 07-18-2013, 04:50 PM   #5
vgi
Drives: frs
could it be rear diff when you just apply gas
vgi is offline   Reply With Quote
Old 07-20-2013, 08:24 PM   #6
BRZPDX
Boosted Member
BRZPDX's Avatar
FIXED:
The noise was coming from the driver side (left) rear axle, and the axle bolt was slightly loose. Tightened it down a quarter of a circle, and voala, no more "click" sound when moving from a stop, and coming from a stop.
The tech is not sure what exactly was causing the noise, but maybe from axle bearing as well since auto-x is hard on them (more so than track I guess).
The Following 2 Users Say Thank You to BRZPDX For This Useful Post:
FRSBRZGT86FAN (07-20-2013), whataboutbob (07-23-2013)
Old 07-20-2013, 10:02 PM   #7
Carwhisperer
Drives: A lot of supercars.
FIXED:
that the clicking noise you are reffering to? starts to make the noise at 0:13
This sound comes from the front right finder area.
Carwhisperer is offline   Reply With Quote
Old 07-23-2013, 03:14 PM   #8
BRZPDX
Boosted Member
BRZPDX's Avatar
Originally Posted by Carwhisperer View Post
VID 20130616 175852 - YouTube that the clicking noise you are reffering to? starts to make the noise at 0:13
OMG the same sound!! You need to tighten the axle nut, from the axle that is making the noise. That solved the issue for me for now.
Old 07-24-2013, 11:25 AM   #9
SkullWorks
Drives: SSM LT MT BRZ
I will be checking my left rear axle nut...I have similar noise on accel or decel
SkullWorks is offline   Reply With Quote
The Following 3 Users Say Thank You to SkullWorks For This Useful Post:
BRZPDX (07-24-2013), Carwhisperer (07-24-2013), feldy (08-06-2013)
Old 07-24-2013, 06:00 PM   #10
Carwhisperer
Thanks, i'll check my front right one. That's where the sound is coming from.
The Following User Says Thank You to Carwhisperer For This Useful Post:
BRZPDX (07-24-2013)
Old 07-24-2013, 07:06 PM   #11
BRZPDX
Boosted Member
BRZPDX's Avatar
have you guys both been auto-Xing, drifting or drive hard a lot? Just curious since this noise started right after a Auto-X sesh for me.
Old 07-24-2013, 10:03 PM   #12
Carwhisperer
+1 for drifting/driving "hard"..
Old 08-06-2013, 07:12 PM   #13
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
FIXED:
I just started to get this last week. Been trying to figure out where the hell it came from. Do you have a picture of what was loose?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-06-2013, 07:13 PM   #14
feldy
feldy's Avatar
Same fucking sound lol glad I found this thread. what axle nut is there I have not been under the back that much to look at the axles. Is it where it goes into the diff or the hubs?
Search this Thread:
Advanced Search
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
soft "clack" sound at 40km/h typericey Scion FR-S / Toyota 86 GT86 General Forum 1 07-06-2013 05:11 PM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
"blipping" the throttle takes more that a blip?! KSC Subaru BRZ General Forum 49 02-27-2013 08:04 AM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
