Old 09-06-2013, 07:02 AM   #1
8686
8686's Avatar
Drives: 86
Light Wight Battery Question
I noticed that our car appreciate wight saving significantly. So I was looking to save wight without sacrificing the Daily Driver reliability.
So I was looking into light wight batteries for a while now but didnt buy one because I wanted it to be installed like an OEM.
Now with PTuning new Battery Tray it triggered the search again.
http://www.ft86club.com/forums/showthread.php?t=46050
I was narrowing my battery options between Shurai and Full Spectrum because they offer the most wight saving.
Shurai LFX36L3-BS12 is used in the famous TRD Griffon.
http://www.ft86club.com/forums/showt...hlight=griffon
While Full Spectrum is used in the Evasive racecar
http://www.ft86club.com/forums/showthread.php?t=39243
below is a small comparison between the two
Battery Cost Wight
Shurai LFX36L3-BS12 (265 usd) (5 lb) [ame="http://www.amazon.com/Shorai-LFX36L3-BS12-Extreme-Lithium-Powersports/dp/B005FIUMOG/ref=wl_it_dp_o_pd_nS_nC?ie=UTF8&colid=3TGLKQSXIDD7 7&coliid=I1A002N0X7L21T"]Amazon.com: Shorai LFX36L3-BS12 Extreme Rate Lithium Iron Powersports Battery: Automotive[/ame]
Full Spectrum P3 (289 usd) (2.2 lb) http://www.fullspectrumpower.com/product/pulse-p3/
In term of more technical comparison between the two, I dont have any idea and here where I am asking for advice. What is the difference between these two? what will be better for a daily driver?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 09-06-2013, 07:24 AM   #2
Captain Insano
When going smaller/lighter battery I always compare the battery prospects I'm considering to the OEM battery Cold Cranking Amps (CCA) rating as I live in a cold weather region for winters. If you don't live in the cold, you can get away with a lot smaller/lighter battery compared to somebody in a cold region.
When comparing CCA of Shurai it is very good at 549 vs OEM is 390 I think. Didn't see a CCA rating for Full Spectrum.
Old 09-06-2013, 07:47 AM   #3
8686
8686's Avatar
Drives: 86
The Full Spectrum have 375 cranking Amps. still close to OEM.
Old 09-06-2013, 10:00 AM   #4
kanundrum
Drives: 2013 Whiteout FR-S
go with Shurai I know a lot of people using them and they rock and where are you located ? Do you have Harsh winters or super hot summers?
Old 09-06-2013, 10:02 AM   #5
8686
8686's Avatar
Drives: 86
all year summer
Sent from my iPhone using Tapatalk - now Free
Old 09-06-2013, 10:03 AM   #6
kanundrum
Originally Posted by 8686 View Post
all year summer
You should be good with the shurai the colds and the harsh summers are really what kills batteries but CCA's come into play in the winter
Old 09-06-2013, 10:09 AM   #7
8686
8686's Avatar
Drives: 86
Thank you for the advice.
I was leaning toward Full Spectrum as it is lighter
Old 09-06-2013, 10:11 AM   #8
kanundrum
shurai is prooven and tried, while personally I have never heard of full spectrum with the shurai only being 5lbs i doubt you will save much more weight. You want reliability not issues.
Old 09-06-2013, 10:38 AM   #9
Hope10Series
#150 FR-S
Hope10Series's Avatar
Drives: FR-S 10 Series #150
Braille 21lbs, 18lbs or 15lbs should do the job. They are great batteries with 2 year warranty.
Hope10Series is offline   Reply With Quote
Old 09-06-2013, 10:42 AM   #10
kanundrum
Id go with oddessey or deka, braille are just rebranded those
Old 09-06-2013, 11:49 AM   #11
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
We can definitely accommodate the Pulse P3 battery on our tray per your question in our other post. Although it is probably one of the lightest LI battery capable of starting the frs/brz. The CCA and reserve capacity of the shorai LFX36L3-BS12 is more inline with what you would want for a daily driver. Now if you were using your car for a dedicated race car, I say go for the lightest battery possible like the Pulse P3 (2.2#) or ballistic Evo2 16CellHD (3.5#) or even the smaller shorai LFX27L3-BS12 (4#).
But even with the largest shorai @ 5#, you're already saving 24+ lbs over the oem battery setup...that is a huge weight savings.
MrC
Mrc@ptuning is offline   Reply With Quote
Old 09-07-2013, 12:40 PM   #12
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We have a lightweight kit as well.
Our Scion FRS and Subaru BRZ Lightweight Battery Kit will shed 19lbs of unwanted weight from your car.
Our kit replaces the stock OEM battery and tray which weights 30lbs with an 11 pound unit. The kit is designed to fit in the factory location with no drilling or cutting required. It bolts right in as per the instructions, and is perfect for SCCA STX class or a track car.
Daily driver cars can also benefit from this kit as it works well for typical daily driver duty. We had it tested for 3 months before bringing the kit to market and ran into ZERO daily driver issues.
This is a simple no nonsense kit and includes:
11LB Braille Battery
Battery Tray Anodized Black
Battery Tie Anodized Black and Laser Etched
Fasteners
Instructions
Battery Information:
This battery has great all around performance for small displacement motors. Using our AGM racing technology it has 904 PCA, more than any other battery in its weight class. Braille Battery’s Advanced AGM batteries have allowed for more power, safer design and less overall weight than the batteries they replace, as the performance leader in the 12 volt sealed AGM (lead-acid) marketplace.
Voltage: 12v
Full Charge Voltage: 13.8v
Short Circuit Current: 904
Pulse Cranking Amps (PCA): 904
Cold Cranking Amps: 360
Cranking Amps: 486
Amp Hour (AH): 15
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-07-2013, 01:58 PM   #13
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
For comparison, the Shorai LFX36L3-BS12:
Voltage: 12V
Cold Cranking Amps: 540A (vs. stock battery: 390)
Amp Hour: 36AH (vs. stock battery: 48AH)
After the Cold Cranking Amps, the most important specification is the Amp Hour capacity. This determines how long it will take the battery to completely discharge under a given load.
Stock battery is 48AH. This means that if you had a 1A load running constantly (say you left the dome light on, and in this hypothetical situation let's say that dome light pulls 1A, for example), the battery would discharge in 48 hours. The Shorai would last 36 hours under the same conditions, and the Braille would last 15.
Not trying to crap all over FT86Speedfactory's product, but it weighs twice as much, with half the capacity, and is only $86 cheaper than the Shorai (when you exclude the mounting kit).
So all these eco-weenies driving their Priuses are actually good for something: They are driving the prices of Lithium batteries down to the point where they are almost as cheap as the older Lead Acid designs.
neurokinetik is offline   Reply With Quote
Old 09-07-2013, 09:43 PM   #14
jm1681
Drives: MKVI VW GTI
Might sound obvious as hell after this discussion, but with the Shorai's CCA well above the stock battery, would it be a safe call running this battery through cold weather (NY winters)?
jm1681 is offline   Reply With Quote
Review of Ptuning Light Weight Battery Mount Kit kanundrum Tracking / Autocross / HPDE / Drifting 18 01-04-2016 12:41 PM
Light weight battery for me? FRSfan111 Electronics | Audio | NAV | Infotainment 2 08-18-2013 10:42 PM
ACDelco Light Weight AGM Battery $27 shipped BRZY Engine, Exhaust, Transmission 11 04-04-2013 05:22 PM
Amplifier battery wire question!?!? mbh1101 Electronics | Audio | NAV | Infotainment 4 03-04-2013 09:07 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
