Old 03-04-2013, 01:12 AM   #1
mbh1101
Drives: Raven 6mt FR-S
Amplifier battery wire question!?!?
Probably hooking up an amp and a sub soon. Anyone know of a good place to run the batter cable for the amp through the firewall ? Any info to save me time would be great!!
mbh1101 is offline   Reply With Quote
Old 03-04-2013, 01:34 AM   #2
cruzinbill
Drives: Argento 6spd FR-S
easiest for a rookie would be the spot on the drivers side grommit. toyota put a spot there for such things, you just have to trim off the nipple.
cruzinbill is offline   Reply With Quote
Old 03-04-2013, 01:35 AM   #3
cnk
Drives: '13 DGM BRZ Limited
There's a rubber piece on the driver's side that you can use. You have to cut the nipple off the end though so seal it with some silicone when you're done passing your wire. It's part of a larger rubber gasket and the wire should come out right under the driver's dash.
cnk is offline   Reply With Quote
Old 03-04-2013, 08:54 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
[ame="http://www.youtube.com/watch?v=LytAyXbgS5w"]Scion FR-S | System 400+ Installation - YouTube[/ame] This video should be pretty helpful for you, even though you're not using their system.
Old 03-04-2013, 09:07 AM   #5
AtlasMick
Drives: FR-S 2013 Asphalt
I wasn't going to post this until I finished my build, but it should be helpful to everyone. Check it out here...
http://www.ft86club.com/forums/showthread.php?t=30276
AtlasMick is offline   Reply With Quote
best way to install 12v wire for amp?? derka-derka DIY (Do-It-Yourself) Guides 5 03-17-2013 12:57 PM
Getting amplifier and subwoofer installed, what should I ask for? 6-Shift Electronics | Audio | NAV | Infotainment 9 02-14-2013 01:47 PM
Hooking up an Amplifier to bespoke questions. 6-Shift Electronics | Audio | NAV | Infotainment 6 01-26-2013 09:52 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
