Old 09-04-2013, 09:32 AM   #1
iJason
Drives: Scion FRS Raven Black
Exclamation Top Quality Coilover brand? *Close Thread Please*
I don't plan on tracking my car but I want a look that's lower than stock, and can keep me from scraping on speed bumps or ramps, or even potholes.
I tend to drive faster than I should with a low car but it is what it is. My FRS is my daily drive.
I'm not looking for anyone's biased "I have HSD coilovers and love them. Haven't ever had a problem."
I want to find the hard facts on each coilover and determine:
Best coilover, unlimited budget
Best, for under around $1200
& the best one for brands under around $800
With my research so far, I've found that Fortune 510 look promising, with a nice warranty, and good customer service. What else is out there?
Last edited by iJason; 09-04-2013 at 06:40 PM. Reason: Got the answer I was looking for.
iJason is offline   Reply With Quote
Old 09-04-2013, 09:48 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Why not just get sti pinks or RCE yellow?
If you have found FA coils promising after reading comments from experienced tuners/drivers than you would probably be happy with any cheap taiwan coilover?
Look through the suspension sub forum there are a couple good threads about cheap suspension components.
EDIT: It is hard to give "facts" as many companies don't give shock dynos and you have to decide who's "professional" advice you are going to listen to when someone is trying to sell you a product. That is why I think the best advice is to look at people who track and daily drive their car for advice. Since you just putt around town an experienced butt dyno from someone like that would be perfect.
Old 09-04-2013, 11:17 AM   #3
You're gonna get what you pay for.
You want a lowered car, but don't want to scrape. You don't want to spend, but want the quality of something that costs a lot.
You need to decide what exactly you want first. Why do you even want coilovers? You can achieve the look you want with just springs. $800 coilovers will give you the exact same look as $8000 coilovers.
Old 09-04-2013, 11:32 AM   #4
iJason
I'm on lowering springs right now; provided by the dealer I got my FRS from. I want coilovers to stiffen my suspension so I don't bounce. I'm scraping right now lol :/ It's bad. Yet at the same time I want a low look. There's got to be some kind of balance. I'm going from 17" tires to 19" for one thing, to cut out my wheel gap.
I considered air suspension at first and was really thinking about it but figured I'd forget it. All I'm hearing is negative things. I just don't know what to do >_<
Also, I drive fast and cut corners quick. All the time. And by quick I mean I lose my traction for a second. Thus; my reasoning for coilovers
Maybe there's another solution to my problem?
The FRS is my first real car. I drove a beat up Honda odyssey before that. I'm clueless and need all the help I can get honestly :/
Old 09-04-2013, 11:48 AM   #5
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Going from 17" to 19" won't actually cut your gap, it's the tire size that matters, 215/50/17 would cut your gap, and allow you to break the rear tires lose easier (providing your new tire is a gt tire like the stockers)
The worst mod I ever did to my FXT was coil overs with a 2" drop, it made it handle amazingly well for a forester but I destroyed my daily driving ability, if there was 27 cents on the floor board driving down normal streets I know that it was 2 dimes a nickel and 2 pennies.
Mind you these were the best coil overs for the fxt, Megan racing custom design 32 settings, around 1200 for the set. I will not be doing coil overs on this car, it's suspension from factory is amazing...
19" rims will also make it harder for you to break free and wiggle ur ass around, just something to think about.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-04-2013, 11:53 AM   #6
Sounds like you want something that high end coilovers provide (good damping), but don't want to really pay the price.
If you're losing traction, get better tires. Tires are the only part of the car that touches the ground, and will make the single largest impact on performance within your budget.
Old 09-04-2013, 11:56 AM   #7
Adeets
OEDC
Adeets's Avatar
Your springs sound like complete shit, that's where most of the bounce cones from, so you might want to look at rally sport direct or something like that for a better set of springs.
My BRZ FI Build
Old 09-04-2013, 11:58 AM   #8
Springs are springs. It just sounds like the OP's springs are too stiff for the stock dampers.
Where you buy the springs from doesn't magically change the spring rates.
Old 09-04-2013, 12:04 PM   #9
iJason
Define high end, and price.. Given that I was originally planning air suspension, my budget isn't too small. $2000 would be the absolute most I'd spend on coilovers.
& yes, I was looking into Nitto stick tires.
@Adeets - I wouldn't be surprised if my dealer gave me shit springs lol, I regret buying the car from them. Should've gotten it 110% stock but what's done is done.
But I don't understand the 17" -> 19" and the 215/50/17. Those numbers don't mean anything to me. Again, I'm new to the actual mechanics of cars but I'm trying my hardest to learn. There's just so much haha. Also, What do you mean break my tires loose?
Old 09-04-2013, 12:05 PM   #10
iJason
True springs are springs but they probably slapped on something cheap with spring rates that don't work for the FRS
Old 09-04-2013, 12:08 PM   #11
Price doesn't affect spring rates, only consistency in the rates.
6k+ is the price an entry level high end damper. At 2k, you're not even in the realm of two way adjustable dampers.
If you want a cheap solution, get some softer springs.
Old 09-04-2013, 12:31 PM   #12
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
I agree, looks like your spring rates are too stiff which would cause your over bouncing. Replace cheap dealer springs.
ApolloSki is offline   Reply With Quote
Old 09-04-2013, 12:34 PM   #13
InvalidJohnny5
The Based God
InvalidJohnny5's Avatar
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Just get TRD springs and call it a day. I mean they were designed by factory and will give you that lowered look you're after. "215/50/17" is a tire size; Width/Profile/Wheel. Like Mike said you're gunna have to spend a bit of coin to get some decent coilovers for racing. I don't see why people concerned with ride height and appearance don't just go for bags. I mean you can clear potholes and get that sweet slammed look and get a feature in Stance magazine.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
InvalidJohnny5 is offline   Reply With Quote
Old 09-04-2013, 12:47 PM   #14
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Do you know what springs the dealer had installed in your car?
gatorbushmen is offline   Reply With Quote
coilovers, daily, racing, stance, suspension
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Coilover Clunk (Brand new) white86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 02-10-2016 10:24 PM
Gas Quality Bonburner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 03-04-2013 08:55 PM
Suggestions needed for a good quality coilover + lots of drop HiiiPwrFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-01-2013 06:48 PM
Good coilover brand for DD ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-26-2012 03:59 AM
